Demo-Blade Showdown – Testing Recip-Saw Blades
We pushed 18 recip-saw blades to their limits to determine their ability to cut quickly and resist wear
9 MIN READ
Test Results in Wood
The nail-embedded test boards worked as I had hoped: They wiped out the blades after an average of 60 cuts each while effectively highlighting the longest-lasting and fastest-cutting models.
To put the rigors of test cutting in perspective, the first-place model made 204 cuts, cutting through 187 feet of 2x6s, 153 feet of OSB, 60 feet of drywall, and 2,448 nails.
Keep in mind that this test was designed to wear out blades – you will probably never encounter 12 nails in a single cut, so I would expect blades to last much longer under normal use.
Snagged nails. I was surprised by the amount of damage caused by the single row of 8d sinkers in the test plank. You’d think 16d commons would be tougher to cut – but the 8d nail snagged in the blades’ gullets and sheared off the adjacent teeth. As soon as one tooth was gone, its neighbors tended to fall like dominos. The 16d sinkers found their way into some of the larger gullets, but the 8d nails seemed to get there first.
Fresh teeth. Another surprise was how drastic an improvement a few fresh teeth can make. The hand-held saw’s foot prevented me from using the first 1/4 inch of teeth out from the tang, but those teeth were in use in the rig saw. The blade could be smoking and sparking during freehand cuts but still cut fast in the rig.
This suggests that you can get immensely more life out of your blades if your saw has an adjustable shoe and you make use of it.
Orbital action. I performed all test cuts in the nonorbital setting, because while every saw can make lineal cuts, only some have orbital. When the main tests were complete, I performed limited testing in orbital mode, and the blade cut noticeably faster and made twice the number of cuts it made in linear mode. I had assumed the blade would wear more quickly cutting metal at this setting, but it didn’t. The reason, a tool-company engineer explained to me, is that inline action drags the teeth over the nails on every return stroke, whereas in orbital mode, the teeth lift off the surface on the return stroke. That lack of friction on the return stroke more than makes up for the deeper biting action of the cutting stroke.
Cutting the Shingle Sandwich
For the roofing planks, I timed cuts 1 and 2, 11 and 12, and 21 and 22. In between, I made hand-held cuts. At cut number 22, I stopped cutting with the bimetal blades, because the teeth in the middle were completely worn away. The only reason they could still cut was that some of the outboard teeth never hit the shingles, so they still cut the OSB. The toothless part of the blade literally melted through the shingles.
The carbide-tipped blades held up better, so I continued with them until cut number 122. At that point I stopped; the blades were cutting more slowly but showed no signs of wearing out soon. Eventually, the carbide tips would have worn away – by my estimate, after two to three times the number of cuts already made.
This test really demonstrated the durability of carbide blades over bimetal blades in abrasive materials. If I had plunge-cut into an actual roof, the bimetal blades would have worn more evenly, and the outboard teeth would have dulled and slowed or stopped in the OSB. I chose not to show the cutting time of bimetal blades in roofing, because no tradesman in his right mind would continue to use a blade that looked as bad as mine did at 22 cuts.
Carbide-Tooth Models
I tested two carbide-tooth models, a Lenox 6563RCT and a Diablo Demo Demon DS0606CW.
The Lenox blade is not intended for use in nail-embedded wood, and sure enough, it failed that test, quickly losing most of its teeth when it hit fasteners. But it did amazingly well in the shingle sandwich, cutting and cutting with hardly any loss of speed. When I quit at cut number 122, the blade was still going strong. It was designed to cut abrasive materials and does very well as long as the teeth don’t experience any shock load.
The Diablo Demo Demon, by contrast, is intended for use in nail-embedded wood. It slowed noticeably as it dulled, but nails couldn’t hurt it. I called it quits when it reached 150 cuts and a 45-second cut time – even though the blade had all its teeth and plenty of life left in it.
The Demo Demon performed admirably in the shingle sandwich but was much slower than the Lenox. That said, if I were cutting into an actual roof I would go with the Demo Demon, because its teeth won’t chip or break off if they hit nails.
Bottom Line
Despite the complexity of this test, I found some simple answers: Of the bimetal blades, the Lenox Gold – which has a thin ceramic coating on its teeth – is the fastest and longest lasting, followed closely by the standard Lenox blade. Third place goes to the Milwaukee Ax, which was well ahead of the rest of the blades.
Because of the speed and longevity of the top bimetal blades, I would not recommend carbide-tooth blades for nail-embedded wood – but for cutting more than a few feet in highly abrasive materials like asphalt shingles, carbide is the way to go. For sawing abrasive material that is free of fasteners, nothing outruns the Lenox carbide. Due to the fragility of the Lenox’s teeth, however, I would recommend the slower but far tougher Diablo Demo Demon carbide for cutting abrasive material that might contain hidden nails.
Michael Springer is the former executive editor of Tools of the Trade, which is where this article first appeared. He covers the tool industry from Longmont, Colo.
Thanks to Grip-Rite for providing the nails used in this test.
Michael Springer
