Diablo Steel Demon Carbide Tipped Recip Blades
Diablo has designed its new Steel Demon Recip Blades specifically to cut through thick metal. Each tooth is carbide tipped so the blades will last 20 times longer than a traditional bi-metal blade, according to the manufacturer. They’re treated with a non-stick coating to help reduce friction and the 1-inch body helps keep cuts straight. The blades are intended for cast iron, stainless steel, and high strength alloys from 3/16 to 1/2 inch thick. Available in 4-, 6-, and 9-inch lengths. Price: $8-15 / COO: Switzerland /freudtools.com
Doug Mahoney
