Eastwood Metal-Cutting Circ Saw
Compact and lightweight, this tool has no problem cutting through rebar.
Do you need to cut only a little bit of metal but still want clean, accurate, burr-free, spark-free, cool cuts?
Check out Eastwood’s Mini-Metal Cutting Saw. At $90, it’s compact and can cut rebar, conduit, sheet metal, tubing, and plate.
The saw has on-board chip collection and its 5-amp motor spins the 4 ¾-inch blade at 3,500 rip ‘ems. The depth of cut is 1 5/8 inches on the tungsten-carbide-tipped blade. Eastwood replacement blades are a mere 12 bucks.
