Bosch says its new saw is an easy-to-transport tool that can make table-saw-quality cuts on sheet goods. The GKT13-225 Track Saw is designed to deliver precision and power, and includes as adjustable track guidance mechanism that aids cutting angle, cut depth, and plunge and finish angle cutting. The track saw can be combined with optional Bosch tracks (sold separately) to deliver straight, fast finish cuts.
The saw features a single pivot point for bevel cuts from -1° (for slight undercuts) to +47°, so when employing the track, you don’t need to position the saw differently for bevel or non-bevel cuts. The track saw’s plunge mechanism ensures plunge cuts with accurate depth of cut thanks to a scale with both inches and metric increments.
The saw includes an efficient dust extraction design that helps deliver a clean work environment. Blade change on the Bosch Track Saw is fast and easy, too, according to Bosch.
