The Fastest Sidewinder Circular Saw on the Market
Hitachi recently added a new pro-level circular saw its saw offerings. This one cuts fast.
Hitachi’s C7BUR 7-1/4-inch sidewinder is designed to be powerful and fast. Dubbed the “RipMax”, the saw’s 15-amp brushed motor runs at 6,800 rpm, which is said to be 40% faster than competitive models. It features an aluminum base, an electric brake, and a dust blower function for clearing the cutline. When outfitted with a fiber-cement blade and equipped with an optional dust collector shroud connected to a vacuum, the unit complies with OSHA’s silica rule. A unique cord hook holds the cord off to the side of the handle to keep it from getting snagged as you make a cut. It has a 2-7/16-inch cut capacity at 90 degrees and 1-7/8-inch cut capacity at 45 degrees. The saw’s bevel capacity is 0-45 degrees. Cost: $170. The saw is also available in a version without an electric brake (model C7UR), which has a bevel capacity of 0-55 degrees and costs $150.
Editor’s note: Hitachi recently announced that it will change its name to Metabo HPT beginning September 2018. Only the name will change; all warranties, model numbers, battery compatibility, and so on will remain the same.
This article originally appeared in Tools of the Trade.
Chris Ermides
