Tool Test: Combination Hammers
Seven combo hammers that chip, drill, and break their way through concrete, masonry, and tile.
13 MIN READ
Publication Date: March/April 2003
Combination Hammers
Tool
Weight
Amps
RPM
Blows Per Minute
Maximum Impact Energy
Cord Length
Street Price
Bosch
11241EVS
14 lbs.
11
220 to 400 (loaded)
1,700 to 3,300 (loaded)
7.4 foot/pounds
8 feet
$549
Comments: This is a terrific, well-engineered machine for someone who does more horizontal work than I do. It’s got great power for a mid-weight tool. It’s well balanced, and vibration isolators prevent excessive vibration and operator fatigue, which is vital. I like the power indicator and speed selector switches. It has a good box. 877-267-2499. www.boschtools.com
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
DeWalt
D25600K
13.4 lbs.
11
140 to 280
1,330 to 2,660
8 foot/pounds
13-1/2 feet
$699
Comments: While lightweight, this tool has impressive power. I like the feel and balance, which is good for horizontal work. The tool exhausts cooling air over a wide area, so it kicks up less dust than the others. I like its dual-mount handle, but when in the upper position by the trigger, it blocks the mode selector switch. The box seems tough enough, but the partitions inside could be a little sturdier. *I tested a prototype model. The tool ships this month. 800-433-9258. www.dewalt.com
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
Hilti
TE 76-ATC
17.4 lbs.
11
0 to 282
0 to 2,770
6.1 foot/pounds
10 feet
$1,699
Comments: This is the most powerful tool in the group, plus it’s the smoothest to operate. It’s balanced enough for horizontal work, although a bit heavy. I like the switches, especially the 50 percent and 100 percent power selection, which increases both the BPM and RPM. The trigger lock for chipping gives your hand a break from squeezing the trigger. The electronic torque control (ATC) is nice. It needs a box that clearly indicates the top and bottom. 800-879-8000. www.us.hilti.com
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
Hitachi
DH40MB
14.2 lbs.
8.7
180 to 360
1,400 to 2,800
5.9 foot/pounds
8 feet
$460 to $500
Comments: This is a solid tool with very good power. It’s well-balanced and ergonomically advanced. I’m not crazy about the switch design and location (underneath the tool body). It’s got the largest box of the bunch, which can carry plenty of bits and accessories. 800-829-4752. www.hitachi.com/hpt
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
Makita
HR4000C
13.6 lbs.
9.6
230 to 450
1,250 to 2,500
4.94 foot/pounds
16-1/2 feet
$565
Comments: I like this hammer a lot. It’s well designed, nicely balanced, and lighter than most of the tools we tested, so it doesn’t quite pack the punch of the others. However, its compact design and variable handle option make it extremely versatile, especially for horizontal work like masonry demo or breakthrough in concrete. The D-handle is a nice addition for horizontal and overhead chipping. It’s got a good switch and well-designed box. 800-462-5482. www.makita.com
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
Metabo
BHE6045S
18.3 lbs.
10.6
105 to 275
1,000 to 2,600
6.049 foot/pounds
13 feet, 6 inches
$839
Comments: Metabo’s is the largest tool of the lot and has enough power to handle any application. It’s a bit heavy for horizontal work but will get the job done well. It’s got a nice, comfortable, and large side handle you can use in two locations — near the chuck and at the trigger grip. I think the function switch needs better graphics to indicate what function the tool is on. 800-638-2264. www.metabousa.com
Tool
Weight
Amps
RPM
Blows Per Minute
Cord Length
Street Price
Milwaukee
5315-21
13.9 lbs.
11
190 to 385
1,700 to 3,400
7.9 foot/pounds
10 feet
$499 to $529
Comments: Milwaukee has a well-made, compact tool with nice features. The vibration isolators really reduce fatigue without compromising tool control and feel. There’s a good switch with clear, concise graphics. The Quik-Lok cord is a nice feature that allows for easy storage in the box and damaged cord replacement. I’m not impressed with the traditional metal box, though, it adds weight and dents easily, affecting proper closure. 800-729-3878. www.heavydutytool.com
This article is reprinted courtesy of Tools of the Trade
