Jackson Pulverizer Demolition Tool
Reach for one of these great tools, and you'll find a solution to the task at hand.
StoryID
1501443
ToolNumber
1
ComponentId
tcm:78-1629239
Jackson has a new demolition tool called the Pulverizer ($43). At 3-1/2 pounds and just under 12 inches long, it’s easy to handle with one hand. It has a 1-1/2-inch-wide hammer face and sturdy claws with serrations for better gripping. The gap in between is for prying and snapping concrete form ties. Just above the rubberized grip is a short wedge-shaped handle section that can’t quite split 2-bys but will tear through drywall – just watch your fingers. The thick prying edge at the end of the tool doubles as a sturdy scraper and provides knuckle protection when pounding on a flat surface. An identical RazorBack branded version of the tool is also available. 800-807-2589, www.jacksonprofessional.com.
Michael Springer
