Makita PC5000C Concrete Planer
Makita. Suitable for a range of concrete finish work requiring dust collection for cleaner operation, the PC5000C concrete planer features a 10-amp motor with soft-start technology for smooth startups and an electronic speed control dial that lets the user match the speed to the application. An electronic current limiter protects the motor from overloading. The tool also includes a vacuum port, and a removable dust shroud cap for easy planing in corners and against walls. With a 5-inch wheel diameter and no-load speed of 10,000 rpm, the PC5000C is designed to smooth concrete seams, remove epoxy from concrete, and more. 800.462.5482. www.makitatools.com.
Lauren Hunter
