Simpson Strong-Tie. DHPD hardwood deck screws are specifically designed for fastening ipe and other hardwoods to pressure-treated joists. A paddle-style drill point eliminates the need to pre-drill holes, and reduces the chance of splitting the wood, the maker says. The screw is able to counter-bore hard material thanks to reinforced mid-wings that let the screw head countersink for a clean, finished look. The collated DHPD screws are made from type 305 stainless steel for corrosion resistance and work with the maker’s Quik Drive autofeed screw fastening system. 800.999.5099. www.strongtie.com.
Rip Cuts Without Saw Marks
Noise-Canceling Earbuds for the Jobsite
A Pressure Washer That Makes Sense
