RotoZip. Built around a 5-amp, 120-volt motor, the new RotoZip RZ2 spiral saw powers up to 30,000 rpm. The saw has full compatibility with the RotoZip system of attachments and accessories. A specially designed cord guard reduces downtime and enhances durability, while extra internal ribbing provides structural support, the maker says. An improved shaft-lock design makes bit changes easier. Two kits are available with accessories to suit different needs. 877.768.6947. www.rotozip.com.
Husky. For effective jobsite clean-up in a small package, try the 2,200 psi Ultra Compact Pressure Washer (model HU80520), available exclusively at The Home Depot. The machine features a 11/8-inch tubular roll cage that protects the Q45 Briggs & Stratton gas engine. The unit has onboard storage for the included 0-degree, 25- degree, and detergent quickconnect spray nozzles. Accessories include a 25-foot, 1/4-inch diameter thermoplastic hose, trigger gun, and corrosion-resistant stainless steel spray wand. 866.340.3912. www.homedepot.com.
Ridgid.
At just 8 pounds, the Fuego 6½-inch compact framing saw weighs 25% less than comparable models. Built for daily jobsite use, the saw has a 12-amp motor running at 6,100 rpm, and it comes with an 18-tooth thin kerf carbide-tipped blade. Other features include an integrated dust blower to clear the cut line for improved accuracy, a soft-grip handle to decrease vibration and fatigue, and a lighted plug that makes it easy to identify when the tool is live. A 12-foot all-rubber power cord stays flexible in cold weather. 800.474.3443. www.ridgid.com.
C.H. Hanson. Snap clean, sharp chalk lines with the Pro150 Turbo Chalk Reel. A full 150 feet of line can accommodate large projects, and a maintenance cap at the end of the line offers easy cleaning so chalk clumps won't clog the reel. A fast-retrieve system allows users to simply push a button, allowing the line to rewind on its own. Made of high-strength plastic, the chalk reel weighs 1 pound and is a tough tool on busy jobsites. Most standard 8-ounce chalk bottles will fit the handy refill chamber. 800.827.3398. www.chhanson.com.
Stanley. The durable box-beam construction of the FatMax Xtreme Level incorporates three block vials for accuracy within 0.0005 inches per inch, and a magnified center vial offers improved visibility. Machined leveling surfaces improve accuracy, while rare earth magnets, stronger than basic strip magnets, are built into the level for stability. With a lifetime accuracy warranty, the level comes in 24- or 48-inch models. Nonmagnetic models are also available. 800.782.6539. www.stanleytools.com.
Hilti. Check vertical alignments with accuracy using the PMP 32 Plumb Laser. The pocket-sized tool lets users transfer points from floor to ceiling, install anchors, align upper and lower drywall tracks, or check for plumb with the push of a button. Featuring a self-leveling mechanism, the Plumb Laser projects a highly visible beam; a flashing beam shows when the tool is out of level. An integrated foot features built-in magnets for a tight grip on drywall track to help increase accuracy in track alignment. 800.879.8000. www.us.hilti.com.
Hitachi. Cut smoothly through tile, marble, granite, brick, and more with the CM4SB2 4-inch dry-cut masonry saw. The hefty 11.6-amp motor produces a no-load speed of 11,500 rpm for greater cutting efficiency through tough materials. Designed specifically for dry cutting, a dust-proof switch and sealed armature coil protect the saw's inner workings from dust and debris. The compact tool weighs just 6.2 pounds. A 4-inch continuous-rim diamond blade is included. 800.829.4752. www.hitachipowertools.com.
Milwaukee. Upgrade nickel-cadmium-powered cordless tools to lithium-ion without purchasing a new tool set. The V18 system features several li-ion tools, as well as a battery and charger compatible with all of the maker's current 18-volt tools. Li-ion batteries charge in 60 minutes; ni-cad in 40. Other tools in the line include driver and hammer drills, a circular saw, and an impact wrench. 800.729.3878. www.milwaukeetool.com.
For more product information, visit ebuild, Hanley Wood's interactive product catalog, at ebuild.com.
