WerkMaster Floor Leveling Machine
The WerkMaster comes in several size and power configurations for knocking down the high spots.
When installing flooring on top of a concrete slab, you need to ensure the surface is flat and smooth. Floor leveler and patching is commonly used to fill voids and raise the floor to the high spots, but additional grinding is often needed and this process requires time and added material costs. Grinding down the high spots, however, can easily be achieved using a WerkMaster machine equipped with its Badger Tooling technology. Because the machine works as a planer, it acts like hundreds of little scabbler heads jackhammering down the high spots, leaving the surrounding area unaffected. Available in several size and power configurations for a variety of project types, The WerkMaster Badger Tooling can also be used to create CSP ratings from 3 through 6.
WerkMaster / werkmaster.com
