2012 Hurricane Season: Too
Soon to Say ~
Traditionally, December is the month when storm-watchers
start to make their forecasts (or, more accurately, their
guesses) about the next year’s Atlantic hurricane
season. Understandably, the top forecasters like to hedge their
bets so far before the fact. On December 7th, for instance,
Tropical Storm Risk
(TSR) predicted a 2012 season slightly more active than the
past 60 years’ average, but slightly less active than
the past ten years. Wrote TSR’s Professor Mark
Saunders and Dr. Adam Lea (both from University College of
London), “Based on current and projected climate
signals, Atlantic basin and US landfalling tropical cyclone
activity are forecast to be about 15% above the 1950-2011
long-term norm but 15% below the recent 2002-2011 10-year
norm.” (See
Extended Range Forecast for Atlantic Hurricane Activity in
2012”)
But the whole notion of a “norm” for
something as chaotic and catastrophic as a major hurricane
— to say nothing of a whole season’s worth of
storms — requires a bit of a stretch. That may be why
this year one of the top names in long-range forecasting has
decided not to make a forecast in December — at least
not with the customary level of detail. Colorado State
University meteorologists Phil Klotzbach and Bill Gray released
their early outlook on December 7
Extended Range Forecast of Atlantic Seasonal Hurricane Activity
and Landfall Strike Probability for 2012,” by
Philip J. Klotzbach and William M. Gray). But the pair wrote,
“We are discontinuing our early December quantitative
hurricane forecast for the next year and giving a more
qualitative discussion of the factors which will determine next
year’s Atlantic basin hurricane activity. Our early
December Atlantic basin seasonal hurricane forecasts of the
last 20 years have not shown real-time forecast skill even
though the hindcast studies on which they were based had
considerable skill.”
“Skill” is a term weather simulation
experts use for a close fit between their projections and the
observed real-world events — or, at least, for a
better-than-wild-guess fit. To demonstrate
“skill,” the Colorado state team has, in
effect, run predictions using its model for years that have
already gone by, and then seen if this
“hindcast” prediction was accurate. But
researchers are forced to admit that they don’t fully
understand the cause-and-effect relationships in long-range
weather patterns, and that their models are too crude to be
reliable. Write Klotzback and Gray, “This is the
nature of the seasonal or climate forecast problem where one is
dealing with a very complicated atmospheric-oceanic system that
is highly non-linear. There is a maze of changing physical
linkages between the many variables. These linkages can undergo
unknown changes from weekly to decadal time scales. It is
impossible to understand how all these processes interact with
each other. No one can completely understand the full
complexity of the atmosphere-ocean system.”
This year, the Colorado State team is basing its assessment
on two key weather drivers:
The Atlantic thermohaline circulation (THC), and the
possibility of a Pacific Ocean El Nino event. A strong THC
would tend to increase storm activity, while a strong El Nino
would tend to suppress storm activity. But the two factors
— a strong THC and an active El Nino — are
assumed to be independent, and the odds of either one occurring
are uncertain. So at this stage of the game, Klotzbach and Gray
give 15 percent odds of a very strong THC with no El Nino,
which would lead to an active hurricane season; 45 percent odds
of a continued moderately strong THC and no El Nino; a 30
percent chance of a continued moderately strong THC plus an El
Nino; and 10 percent odds of a weaker THC plus the El Nino. The
bottom line (if you can call it that):
15 percent odds: 14-17 named storms, 9-11 hurricanes, 4-5
major hurricanes
45 percent odds: 12-15 named storms, 7-9 hurricanes, 3-4
major hurricanes
30 percent odds: 8-11 named storms, 3-5 hurricanes, 1-2
major hurricanes
10 percent odds: 5-7 named storms, 2-3 hurricanes, 0-1 major
hurricanes
Tropical Storm Risk’s forecasters, for what
it’s worth, are basing their assessment on a different
set of factors. Write Saunders and Lea,
“TSR’s two predictors are the forecast
July-September trade wind speed over the Caribbean and tropical
North Atlantic, and the forecast August-September 2012 sea
surface temperatures in the tropical North Atlantic. The former
influences cyclonic vorticity (the spinning up of storms) in
the main hurricane track region, while the latter provides heat
and moisture to power incipient storms in the main track
region. At present TSR anticipates both predictors to have a
small enhancing effect on activity.”
Actually, sea surface temperatures and the thermohaline
circulation are related factors; any attempt to predict
hurricane activity, in fact, has to take into account water
temperatures in the storm region. But the truth acknowledged by
both forecaster teams is that this far in advance, too little
is known about next summer’s conditions to say what
the 2012 storm season will bring.
