by Charles Wardell
People who live on islands understand the meaning of scarce
resources and may be more aware of a home's environmental impact
than the average suburbanite. This marketing assumption panned out
for Peter Taggart when he secured the job on Chebeague Island,
Maine, of building what he calls "the most environmentally
sensitive home we've done to date."
That's saying a lot. Taggart Construction of Freeport, Maine, has
been pushing the green building envelope for a decade. Taggart
serves on the board of the Maine Chapter of the U.S. Green Building
Council, and has served as president of the Northeast Sustainable
Energy Association (NESEA), a network of green builders and
designers who share information with one another. "For years we've
sent staff to the annual NESEA conference in March," he says. "What
we've learned is incorporated into this house."
Designed by Curt Jensch, Taggart's staff architectural designer,
the house is set in a stand of white pine and birch, with
tantalizing glimpses of blue ocean water filtered through the
trees. Jensch went beyond passive solar design to offer natural
daylighting in every room. Photovoltaic panels supply much of the
electricity. Recycled cellulose insulation — R-28 in the
walls and R-60 in the roof — keeps icy North Atlantic breezes
at bay.
"It's not as if you can throw down bamboo flooring and call the
house green," asserts Taggart. You need to understand technical
concepts, like how vapor barriers and rain screens manage moisture,
especially in a damp seacoast environment. "A lot of people these
days want the green label. But what's green is often invisible. It
even comes down to how the framing is done," Taggart says,
referring in part to the home's certified sustainably harvested
framing and siding materials, and the indigenous woods he used as a
substitute for pressure-treated lumber.
Green thinking also helped Taggart handle the expense of barging
materials to, and trash from, the island. A slab-on-grade
frost-protected shallow foundation used much less concrete and
required only minimal site disturbance, compared with the typical
Maine basement. Stem walls weren't poured but built with insulated
fiber-cement blocks. Rather than a dumpster, Taggart's crew had
waste piles for different materials and reused items whenever
possible. The protective pallets used to ship windows, for
instance, eventually found their way back to the house as blocking.
At the end of the job, wood products were buried on site, along
with stumps from the excavation. The wood will naturally decompose
over time, with little or no impact on the island's fragile
environment.
