Think of the atmosphere as a dynamic mass of air with pockets at
different pressures and rivers of air currents holding different
amounts of moisture. Wind is air movement between areas of two
different atmospheric pressures, flowing from an area of high
pressure to an area of low pressure. As water temperatures in the
Atlantic warm, minor tropical disturbances — pressure
imbalances that create flurries of wind and rain — form, but
with very little organization. Such disturbances of slightly higher
intensity, known as tropical waves — a low-pressure
atmospheric front — blow from the coast of Africa over
tropical waters in summer, and bump into similar disturbances in
the Atlantic in the intertropical convergence zone (ITC), then
drift slowly toward the United States. From June through October,
many such pressure disturbances form in the western Caribbean and
are pulled northward toward Florida.
A hurricane is composed of a series of thunderstorms organized
into
rainbands on its outer edges. Air spirals in toward the center in a
counterclockwise pattern and out the top in the opposite direction.
Because hurricanes always spin counterclockwise, the winds are
always stronger on the right, as the forward speed of the entire
storm adds to the speed of the revolving hurricane.
Birth of a Tropical Cyclone A tropical wave can gather into a
tropical cyclone as heat and energy are gathered from the
atmospheric wave's contact with the warm ocean waters. The winds
near the ocean surface spiral into the disturbance's low-pressure
zones. The warm ocean waters add moisture and heat to the air,
which rises. As moisture condenses into drops, more heat is
released, contributing additional energy, forming bands of
thunderstorms within the cyclone. At this point, the storm is
classified as a tropical depression — an organized system of
clouds and thunderstorms with a defined circulation and sustained
winds up to 38 mph. As the storm gathers, its cloud tops rise
higher into the atmosphere, and if the upper level winds remain
relatively light (with little or no wind shear), the storm is not
dispersed and continues to strengthen into a tropical storm —
officially explained as an organized system of strong thunderstorms
with a defined circulation and maximum sustained winds of 39 to 73
mph.
The Eye of the Storm
A tropical storm becomes a true hurricane when the winds reach a
minimum of 74 mph. At wind speeds of about 80 mph, a distinct
"eye," or "chimney," appears when the rapid drop in pressure
created by the swirling winds forms at the center of the storm. The
drop in pressure pulls in warm moist air from hundreds of miles
around and causes the center temperature to rise at an even steeper
rate, accelerating the evaporation of moisture from the ocean
surface. This moist air is carried thousands of feet up the
chimney, where it is spewed out in the cold, dry air high above,
forming an even greater mass of moisture-laden clouds. Round and
round, and up and down, this transfer of energy perpetuates the
cyclone generator.
Storm's End
Landfall typically shuts off the hurricane's main moisture source,
and the surface circulation is often reduced by friction when it
passes over land. Moving over cooler water may also rob the storm
of energy, or wind shear may tear it apart. However, the remnants
of a weakening hurricane can still cause considerable damage, and
can always re-intensify if it moves to more favorable regions.
— Clayton DeKorne (adapted with permission from
"Hurricane Basics" http://hurricanes.noaa.gov/prepare)
