Ted
Cushman
Strict wind-resistant construction requirements in the 2003
International Residential Code (IRC) and International Building
Code (IBC) can be a headache for many beachfront builders. But
architects and contractors who work with structural insulated
panels (SIPs) say the new rules could bring them a new competitive
advantage — or at least, for once, a level playing
field.
SIP builders have long complained about the need to get
project-by-project approval to use their technology: They say SIP
structural capabilities are well proven by engineering data and
field experience. But for building departments that may not have
seen a lot of SIP construction, requiring an engineered design may
be the only path to assuring adequate performance of an unfamiliar
system.
For houses in 110-mph and higher wind zones, however, states and
municipalities recently adopting the 2003 IBC and IRC are now
requiring an engineering analysis on virtually all homes, whatever
the framing system used. SIP builders say this may erase one of the
big negatives that has handicapped SIPs in the market — at
least when it comes to building on the oceanfront. In the areas
where stick-home plans need as much engineering documentation as
SIP homes need, builders who choose SIPs are no longer facing any
special hurdle.
On a Long Island home, architect Bill Chaleff relies on
structural insulated panels (SIPs) to easily meet stringent uplift
requirements.
Architect Bill Chaleff designs and builds with SIPs on the east end
of Long Island, where design wind speeds are set at 120 mph.
Chaleff says SIPs are more than up to the code challenge: "I've
already gotten permits for two houses, one in East Hampton and one
in Southampton, under the new building code here, by showing my
calculations to the building department to demonstrate that I can
meet the required design loads."
Understanding and Documenting
Uplift
Hurricane-force winds apply a variety of stresses to a building. If
a home lacks adequate shear walls and anchors, horizontal wind
pressure tends to collapse wall systems or overturn the entire
building, or the "sliding force" of the wind may simply push the
building off its foundation.
In addition, there's wind uplift. As wind flows over a pitched
roof, aerodynamic effects create an upward suction, much like the
uplift force that acts on an airplane wing (Figure 1). If roof
sheathing isn't adequately nailed, boards or panels can get ripped
off the roof framing (see "Evaluating OSB for Coastal Roofs,"
Winter 2005).
Figure 1. Wind passing over a building exerts
positive pressure on the windward wall and negative (suction)
pressure over most of the roof area. The wind pressure is
concentrated at building corners, where eddies exert extra
forces.
But if the sheathing does stay attached, it pulls upward on the
rafters or trusses. These in turn pull up on the roof-to-wall
connection, and if that survives, wall systems pull up against
their attachment to the floor systems or foundation systems at
their bases.
For coastal homes subject to the strict requirements of the current
IBC and IRC, building departments will now require a design
professional — architect or engineer — to document how
a building resists this uplift force. The plans must show a
"continuous load path" that handles the uplift at the roof surface
plane and transmits it through specified connections of known
strength down through the roof system, the wall system, and into
the foundation. How the load-carrying task is accomplished varies
from one structural system to the next, but in every case, it must
be documented.
Documenting starts with estimating the uplift forces on the roof
sheathing and overhangs. That can be done with calculations or with
look-up tables. The result is a drawing that shows the entire roof
surface hatched into segments, with a design uplift load designated
for each section of roof area. Ridge and eaves zones experience
higher uplift than mid-roof areas, while roof corners see the
greatest uplift loads. If flying debris breaches windows or doors,
internal pressurization caused by inrushing wind could drastically
increase the total uplift pressure on the roof.
With design uplift load established, the design professional must
specify step-by-step how the load will be transmitted through the
building structure down to the ground, specifying adequate
connections at each structural intersection.
Uplift Details
For roof-to-wall connections, Chaleff applies the high wind uplift
values from roof corners to his entire roof. He then distributes
that load over the roof-to-wall joint, secured by long hardened
screws and hand-driven nails (Figure 2). He requires the outside
walls to handle the entire uplift load, disregarding field
attachments to midspan purlins or ridge beams, because only the
wall panels provide a direct load path to the foundation wall. "I
didn't have to change anything about the way I fasten the panels
together," he notes. "I'm meeting the new wind codes using the same
fasteners at the same spacing that I have always specified for our
designs."
Figure 2. In SIP construction, wind uplift loads
can be resisted by self-tapping structural screws at roof-to-wall
panel joints (A). In addition, metal straps spanning the upper and
lower wall plates at the band joist (B) and anchors that secure the
panels to the foundation (C) are required. "Balloon framed" SIP
structures that use a continuous panel from foundation to ridge do
not require the straps between stories, but the supporting
attachment for the floor systems must be carefully specified.
Additional anchors may be needed for shear-wall
connections.
By contrast, says Chaleff, stick methods in coastal zones now
involve complicated framing reinforcement (Figure 3). "To meet the
uplift loads induced by a 120-mph wind, they have to put hurricane
straps on every rafter or truss and on practically every stud, and
they have to strap from stud to stud across the band joist between
the first and the second floor. It can add $15,000 to the cost of a
big custom house." The difference makes SIP homes cost-competitive
with stick homes in his area, says Chaleff — leaving him free
to focus on the energy performance advantage of his preferred
building system.
Figure 3.In high-wind zones, the steel
connectors required to create a continuous load path to resist the
wind uplift of a stick-framed assembly often include straps to tie
trusses to wall plates (A), wall plates to studs (B), upper wall
studs to band joists (C), band joists to headers, posts, and lower
wall studs (D), posts to foundations (E), wall studs to lower wall
plates (F), and lower wall plates to foundations (G). Additional
anchors may be needed for shear-wall connections.
Fewer Connections
At least one Florida house has already provided a test case for SIP
homes facing storm winds. Builder Cameron Bradford was the general
contractor for the "Not So Big" Show House at the 2005
International Builders Show, a showcase home framed using Insulspan
SIP panels (www.insulspan.com). The building was hit by three
hurricanes in a row while still under construction in the fall of
2004.
"Hurricane Frances brought 105-mph measured winds at the airport,"
Bradford says, "and our house survived without any damage at all.
We didn't even have the windows or doors in yet, and the wind came
right inside the building." But with SIP exterior walls and a flat
SIP ceiling on the second floor supporting a truss roof, the
Orlando house is "built like a plywood bomb shelter," notes
Bradford. "It was not damaged at all."
Simple connection details were a real plus, reports Bradford: "The
biggest advantage is the speed of construction." The house took
just four days to set, he says, "and that's including our learning
curve, using SIPs for the first time." Tying the house down was a
snap: "We used Simpson hold-downs at every panel joint into the
slab foundation — that was definitely overkill. Then we had
flat straps spanning the first-floor frame, just at the panel
joints.
"In a stick frame, you're installing two connectors for every stud,
and six or eight nails per connector," he explains. "That is a lot
of nailing. The SIP walls were much, much faster."~
Ted Cushman reports on the building industry
from his home in Great Barrington, Mass.
