Andrew P.
DiGiammo
When I'm driving through neighborhoods in coastal Rhode Island and
Massachusetts, where I design and build custom homes, I keep an eye
out for interesting design elements on both new and old houses. In
the past eight years, I've noticed a resurgence of polygon
bump-outs, round towers, and multifaceted bays. I've been using
polygons in my own work since I started designing and building
homes. For beginners, polygons can seem tricky to work with, but
they are not difficult if you have a basic understanding of
geometry. And they're worth the effort: A nice bay or many-sided
projecting room can serve various purposes in a house design.
Aesthetics Are Only Part of the Equation
Visual aesthetics are just part of a bump-out's value. A many-sided
projecting room with windows adds interest to an elevation (Figure
1), and it can serve to capture a nice view, which is especially
important for homes near the ocean. But round or polygonal
projections can also help the way a space functions. In a coastal
home where wind loads are a factor, some walls may need to be
nearly windowless for structural reasons, and interior shear walls
can create long, narrow rooms. Projecting bump-outs with angles,
curves, and windows can bring light into these areas, creating
interior spaces that are strong and sheltering while still
welcoming in the outdoors. And by the nature of its shape, the
attached polygon becomes a buttress, contributing strength to the
house through its geometry.
Figure 1. A multisided projecting room with windows adds
interest to the elevation and brings in light while offering
expansive views. The tower is a section of a duodecagon — a
12-sided figure that can be readily adapted to a circular form on
the outside.
Polygon rooms can even be an economical feature for a project where
the budget is limited. I like to start with a simple rectangular
footprint, then enhance just one or two rooms by adding a bay or a
circular or polygonal projection. That way, I can provide a
spacious living or dining area without having to make the whole
house wider.
I always use a pure geometric form: a polygon with equal angles and
equal sides. That symmetry simplifies the framing (Figure 2) and
helps prevent an awkward-looking result. But I don't limit myself
to octagons — I choose the shape that will do the most for me
in the particular situation. Computers have made my life easier by
eliminating the need to work the trigonometry for each option. If I
specify the number of sides and the diameter of the polygon,
AutoCad generates the shape and allows me to place it wherever I
like.
Figure 2. Using a pure geometric form helps maintain simplicity
and symmetry in design massing, as well as in construction details
such as roof framing.
Twelve Faces
The duodecagon, or 12-sided figure, is probably my favorite. It
tends to work well with typical room and window dimensions: Twelve
faces (or six, if I'm using only half of the figure) can gracefully
define a room that is 12, 14, or 16 feet wide, and the dimensions
of each wall panel tend to work well with window sizes, leaving
just enough wall space around each window for comfortably sized
trim.
A 12-sided figure creates angles gentle enough to be readily
adapted into a circular form. When I create circular towers or
round rooms, it's usually only the outside of the room that is
finished round. My crew frames up the room with flat walls, then
ties all the wall sections together and sheathes them for strength.
We can then set all our windows into the flat wall panels, which is
much more practical than trying to set them into a round wall. We
apply curved windowsills to the exterior, and furr out the outside
walls horizontally with pieces ripped from wide 2-by stock, with
the proper radius curve on the outboard face and the flat inside
face nailed against the wall. Placing the furring at 5 inches
on-center or so, we can nail shingles right to the furring to
create a smooth, curved shingle face around the whole outside wall.
Inside the room, we stick to the flat-sided polygon shape, using
mitered baseboard and mitering the window trim so that the side
casings meet in the room corners (Figure 3).
Figure 3. A figure with 12 or more sides can be adapted to a round
exterior shape with curved horizontal furring. Inside, the windows
bring in views, light, and air, and staying with a flat wall
surface allows the use of simple mitered trim details (bottom).
Upstairs (top), the curved, windowed wall opens up the end of a
long hall space defined by structural walls.
When you think about it, this can be the simplest way to treat that
rounded space. It saves us from having to create all the angles and
corners on the outside, with multiple beveled corner boards or
other complicated carpentry, but it also lets us stay away from
curved drywall or baseboard on the inside of the room. The result
is a space that is interesting when viewed from either the inside
or the outside, opening up the interior and taking full advantage
of light, views, and cross breezes. — Andrew P. DiGiammo
is a design/build contractor and a partner in an architectural firm
in Assonet, Mass. All photos by Ted Cushman.
