by David Bentley and
Elizabeth Churchill
Surrounding any home with an abundance of flowering plants not
only enhances the structure but also helps to integrate the
building into the natural environment. Perimeter planting beds
around a home's foundation, laid out in picturesque curves, soften
the edge of the structure, merging it into the landscape. This is
especially true for homes at the coast, where the lack of trees and
other larger vegetation can give a house without added landscaping
flourishes a particularly desolate, even tenuous look. In such
cases, simple features such as window boxes, overflowing with a
variety of blooming colors and textures, and trellises, covered
with roses or other flowering plants, are particularly useful for
highlighting the beauty of the house while further anchoring it to
its surroundings (Figure 1).
FIGURE 1. Flower boxes combined with wall and
roof trellises provide a traditional flourish to the fisherman
cottages of Siasconset, Mass.
Successfully incorporating plantings in and around structures to
achieve this natural, seemingly effortless look, however, requires
careful attention to construction detailing. To promote drying,
adequate ventilation must be provided between plants and wooden
materials. The use of durable species and the timely maintenance of
paint and other finishes will also contribute to the long-term
compatibility of plant materials with the house.
Window Box Gardens
We've had the best success with window box frames supported on
wooden brackets attached with two 3/8-inch-diameter hot-dipped
galvanized lag bolts into studs beneath the window. To increase the
life of the window box, we construct it from western red cedar,
leaving an open bottom. Two struts span the sides of the box to
support the type of plastic plant liners that are readily available
at most hardware stores and nurseries (Figure 2). Maintain a space
of at least 1 inch between the box, the windowsill, and the wall to
allow drying.
Window box treatment
FIGURE 2. Constructed of western red cedar,
the window boxes are designed to hold conventional plastic plant
liners, with the bottoms open to prevent them from rotting
out.
Owners can get a jump on the season by starting the plants indoors
in the liners in the early spring before placing them on the house.
Plants we've had success with in containers include geraniums,
lobelia, alyssum, impatiens, nasturtium, verbena, and petunias. Ivy
geraniums and other trailing plants add an especially picturesque
quality to the dwelling. As window boxes tend to dry out faster
than planting beds in the ground, use a soil mix that promotes
water retention (Pro-Mix; available from plant nurseries and
hardware stores). Regular watering with a liquid fertilizer, such
as Miracle-Gro, will promote vigorous plant growth.
Rose Trellises
The rose-covered fisherman cottages of Siasconset, Mass., are
widely known for their quaint scenic charm. Wooden trellises
support climbing roses up the walls and over the roof, literally
covering the houses. Traditional varieties of rambler roses used
for trellises include the miniature double pink ‘Dorothy
Perkins' and the single deep pink ‘American Pillar' with
white center. A prolific newcomer, the large double light pink
‘New Dawn' rose, will rapidly cover the walls and roof.
We recommend rose trellises (preassembled on the ground before
installation) constructed from 1x2 western red cedar, left
unfinished to weather. The verticals are attached to the house with
stainless-steel screws, and the horizontals are placed over these
to hold the rose canes away from the house to promote drying
(Figure 3). Roof trellises should be attached to strips of
lead-coated copper flashing layered into the roof shingles to avoid
penetrating the roofing. Trellises can be removed from the building
and laid back, with roses still attached, for maintenance of the
siding or roofing beneath.
Rose trellis detail
FIGURE 3.When attaching trellises to
a house, secure the verticals against the house and the horizontals
over the verticals. This will hold the rose canes away from the
building finish to promote drying.
Used as a design element, rose trellises can balance windows,
doors, and other features in composing building elevations. Lattice
spacing can be varied to fit wall areas between openings to create
a continuous grid across the wall. Roof trellises can be aligned
with wall trellises to express an overall grid over the entire
exterior. To define a larger grid, double up trellis units.
Concentric arrangements, spider web configurations, and other
geometric patterning provide an extensive variety of
expressions.
"Summer Houses"
Beyond the two-dimensional representations used to decorate
building surfaces, rose trellis can also be extended into three
dimensions to define architectural space. A trellis-covered deck
can be attached along one or more sides of the house or constructed
as a freestanding garden pavilion, sometimes referred to as a
"summer house." In our renovation of a 1920s Colonial Revival house
in Siasconset, the owners asked for a deck on the water side of
their house. To integrate the deck with the historic character of
the house, a porch addition would have been the traditional
approach, but the owners did not want to lose any of the daylight
through the colonial sash windows. Our solution was to extend an
existing trellis-covered seat outside the back door into a
trellis-covered deck overlooking the ocean (Figure 4).
FIGURE 4. Appearing as a traditional attached
porch, the trellis-covered deck on the sea side of the house offers
a combination of shade, privacy, and naturally framed views of the
ocean.
We retained the existing antique climber roses growing on either
side of the door by framing the deck around them. The trellis
structure, painted to match the house, was constructed of 4x4
Doug-fir beams and columns, spaced approximately 6 feet on-center,
with 2x4 rafters spaced 24 inches on-center. The ends of the rafter
tails were shaped with a simple profile. Around the corners and
over the arched seat, we used curved beams built up from thin
layers of wood laminated with epoxy. To support the roses across
the rafters, we laid 1x2 western red cedar lattice strips, left
unfinished, 12 inches on-center. Profiled 2x4 top and bottom rails
span the distances between posts, with 11/4-inch-square balusters
evenly spaced approximately 5 inches on-center.
Covering the deck with the rose trellis creates an ideal transition
space between indoors and out (Figure 5). The natural ceiling
provided by the roses, combined with additional roses planted
around the outside to climb the support posts, defines the deck as
an extension of the interior space while at the same time remaining
part of the natural surroundings. — David Bentley
and Elizabeth Churchill, architects on Nantucket Island,
Mass., have been building seaside homes for more than 20 years. All
photographs and details are by the authors.
FIGURE 5. A trellis-covered deck provides a natural
transition between indoors and out. The deck beneath the trellises
was framed conventionally with 2x6 pressure-treated joists, spaced
16 inches on-center, and supported by a spaced ledger against the
house and by a 6x6 grade beam on 12-inch-diameter concrete piers
around the perimeter. The decking itself is 3/4x4 Doug fir, spaced
1/8 inch apart, nailed to the joists with stainless-steel
ring-shank nails.
