by Ted
Cushman
At their 100% employee-owned building and remodeling company on the
island of Martha's Vineyard, the workers at South Mountain Company
are essentially their own bosses. They make it a priority to find
their own motivation, and the same independent, adventurous
mentality that's typical of clients on the island offers them ample
opportunities for creative innovation. It's as if the island
itself, which sits apart from the Massachusetts mainland, has
inspired a certain independent mind-set among the residents and
workers alike. This is a market, and a company, that's not afraid
to venture off the grid.
Phil Forest, one of South Mountain's employee-owners, has
discovered this quite literally in his pursuit of photovoltaics.
Forest didn't join the company just to do photovoltaics, he says:
"I came on board to build cabinets and do finish carpentry." But in
building his own solar-equipped, energy-efficient island home, he
learned to "love the renewable energy stuff." In recent years,
clients on the Vineyard have begun asking a lot of questions about
wind- and solar-generating technology. For Forest, that provided an
opportunity: with backing from the company, he explains, "I started
to take renewable energy on as my new career."
Production manager Charlie Morgan (left) and Ben Philbrick of
Rhode Island-based SolarWrights maneuvers a photovoltaic panel into
position on the roof of a Connecticut home. Then State of
Connecticut puts up a per-kilowatt subsidy that makes the upfront
cost of PVs easier to swallow — a trend that may catch on in
other states as green building incentives become an increasingly
important issue for policy makers.
Together with coworker (and co-owner) Rob Meyers, a trained energy
rater who handles design work and estimating, Forest is widening
this niche for the company, installing solar water heaters and
wind-turbine generators as well as solar electric panels. In the
past year, South Mountain's renewables team has moved into the
existing home market, offering energy audits and solar or wind
power systems to anyone who has an interest.
As a self-taught solar enthusiast, Forest says, "I am by no means a
long-term renewable energy expert. I'm still catching on —
just as the building officials and the electricians are." But South
Mountain plays a key role as the general contractor: "We design the
projects, we order the equipment, we coordinate with the homeowner
and the electrician and any other subs that need to be involved. We
do some of the work ourselves on the roof, installing the mounting
hardware and setting the panels." For large jobs, South Mountain
turns for help to a solar specialist from the mainland, Rhode
Island-based contractor SolarWrights (www.solarwrights.com). But as Forest puts it, "You
don't have to have been doing solar for 20 years in order to make
solar part of a remodeling business."
First Step: Conservation
Solar panels are a costly investment, and they may not be for
everyone. Clients need to address their electricity consumption
head-on. Forest starts by helping clients find efficiency upgrades
to limit their electricity needs. In new construction, the design
process emphasizes conservation from the beginning; for existing
homes, the first step is an energy audit to zero in on easy
savings.
"If someone wants solar panels," explains Forest, "first we'll go
around the house and say, ‘Look, you could change these 10
light bulbs, and replace that 20-year-old fridge, and you won't
have to have as big a PV system.' By reducing the load, you've just
achieved, for less money, what you would have gained by investing a
lot of money to generate renewable energy."
The same logic applies to new building design, says Forest, but
there is even more room to maximize the savings. South Mountain's
latest solar project was a "net-zero carbon footprint" home —
a super-insulated house with 6.4 kilowatts of roof-mounted solar
generating capacity, designed to produce as much energy as the home
uses on an annual basis.
Triple-glazed south-facing windows, a well-insulated and tightly
sealed building enclosure, compact fluorescent lights, and
efficient appliances trimmed the house's heat and power needs,
while two pellet stoves (one upstairs and one downstairs) supply
the home's heat without electric pumps or fans. But conservation is
not about sacrifice, says Forest: the occupants enjoy all the
comforts of modern life. "There is no compromise with this house,"
he says. "In fact, I think it may be more comfortable than a
conventional house, just because of the warm walls and the
daylight." Appliances like the refrigerator and stove are sized to
meet the family's needs: "We tell people to shop for exactly the
size they need — not bigger, but not smaller either —
and then we just tell them to choose the most energy-efficient
model available."
Phil Forest (far right) expanded South Mountain Company's
remodeling business to include renewable energy services — a
niche he obviously enjoys with company renewables sales manager Rob
Meyers (immediate right) and Martha's Vineyard electrician Steve
Gallagher (center).
But the designers relentlessly squeezed out a few watts of savings
wherever they could find them. One example is the home's Grundfos
well pump — a variable-speed unit designed to supply water at
constant pressure, whether it's a trickle at the kitchen sink or a
rush for the lawn sprinklers. The advanced pump uses a little less
power than traditional one-speed well pumps (which have to work
against the pressure of a storage-tank bladder). "We ran some
calculations, and it's not a tremendous electrical savings," says
Forest. "But it is more efficient. And when you combine 10
approaches like that in a house, where every single one makes a
small difference, then you get significant improvement in your
household load."
Solar System Choices
In the world of photovoltaics, there are three main
approaches.
Grid-tied. Panels may supply some of the house's power,
all of it, or even more than it needs. When it's dark or cloudy,
the house draws power from the street; when the panels make extra
power, the surplus is fed back to the utility power lines, spinning
the meter backward. Depending on state law, the utility may pay for
any monthly or annual surplus production at wholesale or even full
retail rates.
Grid-tied with backup. Besides the grid link, the system
can be set up with a battery bank to supply critical loads —
refrigerator, well pump, and a few lights — in case power
from the street fails. Unlike basic grid-tied systems, which have a
code-required safety cutoff that disconnects the panels during a
power outage to protect utility repair workers, a battery-backup
system with appropriate safety switching still lets the panels
power part of the house when the grid is down (as long as there is
sunlight).
Off the grid. Fully independent systems with panels big
enough to power the entire house, plus charge batteries for use at
night or on cloudy days. A backup generator will probably be needed
to ensure no interruption of service.
Grid-Tied
Grid-tied systems are the simplest, requiring the fewest components
and the least expense. Where no local subsidies are in place to
offset the initial costs, these systems are the easiest to
justify.
Grid-Tied with backup
Grid-tied with backup. While these add some complexity and expense,
a grid-tied system that has a bank of batteries (4) will provide
power even at high-demand times in the event of a power outage
— not a bad idea for a coastal location.
off-grid
Off-the-grid systems are the most complex and expensive. In remote
locations where utility lines do not exist, the costs are much
easier to justify than they are where utility service has already
been established.
Completely off-grid systems are the most costly and complicated.
Balancing the panels and the batteries against the varying daily
load is tricky. Sometimes extra solar power goes to waste, but at
other times even the best systems need occasional help from an
ordinary propane or diesel generator. Batteries add cost and
complication, require maintenance, and have to be replaced when
they wear out. Forest has never installed a purely off-grid setup.
South Mountain has provided a couple of grid-tied systems with
emergency battery backup; but for the most part, islanders have
chosen to tie their systems to the grid and skip the
batteries.
The simplicity of the grid-tied system is its greatest appeal. The
panels on Forest's own house, he says, are sized to produce
somewhat less than the building consumes on average, even in summer
months. "It's a great system, because I'm using the power grid like
a very efficient battery, without having to have a complicated
battery system," says Forest. "When I make excess, I store it out
in the grid. And when I want it back, like at nighttime, it just
comes back to me again."
POWER UP.
Rooftops are an obvious location for PV panels, but there's not
much point in undertaking an elaborate installation that will have
to be disassembled in a few years, so it's critical that they go
down over new roofing. The panels get bolted to extruded aluminum
rails (left and top), which are mounted on a series of L-brackets
(above). The brackets are lagged into framing every 6 feet on
center (every third truss) with liberal amounts of silicone caulk
to seal the penetration — a system that is rated for wind
speeds up to 125 mph in Exposure-C conditions, and according to Bob
Chew of SolarWrights, who has more than 30 years in the industry,
weathers well without leaking.
Solar Economics
Most people who use electricity pay for it as they use it, month by
month. But when you buy photovoltaic panels, says SolarWrights'
founder and 30-year solar veteran Bob Chew, "you're buying an
electric generating appliance that is going to generate, say, 30
years of electricity, and you're paying for it all up front."
Depending on the size of the system and the difficulty of the
installation, says Chew, his crews can install solar generating
capacity for between $7 and $11 a watt. "On big systems we get
economies of scale," he notes. "So, for example, yesterday I
measured a 1-megawatt project. That's a huge job, and so that's
going to be at the low end of that range. But for a 2-kilowatt
system on a difficult roof, it might get as high as $11 a watt. The
average is around $8 to $9 per watt, before incentives."
At those prices, Chew says, PV-generated electricity can't compete
with utility power prices in New England (unlike in sunny Southern
California, where the price of solar power is now close to parity
with utility rates). However, the federal government and many state
governments provide tax incentives and even direct subsidies that
can make solar panels a reasonable investment, depending on where
the homeowner lives.
Rhode Island recently canceled its state subsidy for solar power.
"In Rhode Island," says Chew, "we tell people right up front that
photovoltaics systems aren't a good financial investment, although
we think they are a good social investment." Next door in
Connecticut, however, the state puts up a per-kilowatt subsidy that
goes into the contractor's pocket. "For installing a 4-kilowatt
photovoltaic system, we'd get about a $16,000 incentive from the
state," says Chew. For larger systems, the rebate would be
more.
Plug and play.
These Kyocera PV panels are equipped with wires and plugs, allowing
the panels to be connected in series as the array is mounted on the
rooftop rails (left). Workers connect the plugs as they go (above).
Connecting the entire array through the power inverter into the
building's main electrical panel on the ground calls for a licensed
electrician.
Based on that math, says Chew, a rooftop solar panel in Connecticut
pays for itself in about 12 years. After that, the power is free
for as long as the panel lasts — "and the industry expects
those panels to keep making electricity for at least 30 years,"
says Chew. "If you can have something paid off in 12 years that's
going to generate electricity for 30-plus years, it's a good
investment."
A typical house would need more than 4 kilowatts of capacity to
break even on power. "You need about 6 kW for a medium electric
load," says Chew, "and a 10-kW system would take care of most
houses. We do a lot of 6-kW systems and an awful lot of 10-kW
systems." Depending on the panel brand, a 10-kW solar installation
would require about 820 square feet of rooftop real estate, says
Chew.
As South Mountain Company discovered on Martha's Vineyard, there's
a strong market for photovoltaics despite the high upfront costs.
"People are asking us, ‘Hey, can I put PV panels on my
house?' " notes Phil Forest. "They're coming to us. That's what is
making this a viable business."~
Contributing editor Ted Cushman has been covering
construction business and technology since 1993. All photos by the
author.
