Coastal environments, almost by definition, are sensitive
ecosystems. One of the biggest threats to the coastline's
health is sewage. Even widely separated houses can cause
harmful pollution to estuaries and bays if their septic systems
don't perform well.
In Maryland, the state's environmental agency has been
tackling the problem one house and one septic system at a time.
The Maryland Department of the Environment is offering free
septic system upgrades worth $12,000 to homeowners in sensitive
coastal areas — paid for by a $30-per-year assessment
on all houses served by onsite systems. It's all part of a law
passed in 2004 that created a Bay Restoration Fund, intended to
reverse worsening pollution in the Chesapeake Bay (the fund
also pays for improvements on municipal sewage treatment
systems that aren't performing up to par). DelMarvaNow.com has
the story of one happy Deal Island, Maryland homeowner
Free septic upgrades offered," by Greg Latshaw).
In the Deal Island example, the solution was a drop-in
septic tank replacement with a small-scale, powered treatment
system developed by
Bio-Microbics, Incorporated. The system uses an
above-ground air pump to aerate and agitate the contents of the
septic tank, allowing micro-organisms that live on a synthetic
medium within the tank to efficiently break down the waste in
the tank. The resulting septic effluent is low in nitrogen, and
won't create clogs in the septic drain field, the company
explains. In fact, they say, a retrofit installation can break
down existing mats of growth that may be clogging the drain
field from the old system's operation. For a video of the
system in operation, look
here.
Small-scale sewage treatment technology has been advancing
for years. Some systems are based on aerobic treatment like the
Bio-Microbics unit; others, such as the recirculating sand
filter systems from
Orenco
Systems, Inc., pump liquid instead of air. And the new
methods are not restricted to single-home solutions, says
alternative wastewater treatment expert Anish Jantrania.
Depending on the need, they can be scaled up to serve a dozen
homes or a whole development.
Jantrania studied the technology in the 1990s at the
University of Rhode Island, where he helped state environmental
officials implement innovative methods to address pollution of
the state's shellfish beds, caused by failed septic systems on
shore. (Jantrania's authored a feature article for the January,
1997, issue of the Journal of Light Construction, called
Alternative Septic Systems. (Requires online membership to
JLC Archive.) Jantrania went on to work for the State of
Virginia developing policies for wastewater treatment solutions
for individual home sites. He now works for
NCS
Wastewater, a company that does design-build management for
larger-scale systems, targeting the niche that falls between
the single-home septic system and the full-scale municipal
treatment plant.
Traditional development patterns, says Jantrania, tend to
fall at one or the other extreme: either an urban model, where
homes are served by a single very large treatment plant, or a
dispersed rural model, where each house uses part of its lot as
the dispersal field for an individual septic tank. But
technology offers a superior third way, Jantrania argues. With
modern methods, he says, you can develop a site so that homes
are clustered more closely within a space too small to allow
for individual drain fields — but use parts of the
freed-up open space for a shared drain field able to handle the
entire cluster's wastewater. The result, argues Jantrania, is a
settlement pattern with lower environmental impacts, a more
livable community, and more open space. For an example, he
points to a neighborhood west of Richmond, Virginia, called
Fox Glen," where an NCS Wastewater-designed system enabled
25 homes to be constructed on a site that would otherwise have
allowed only 12 — but with a smaller total footprint
than those 12 homes might have applied.
Similar strategies can work in sensitive areas nearer the
coast, says Jantrania. "In coastal areas, there are nutrient
issues — nitrogen, phosphorus — and so we try
to find nutrient reduction technology, and find the right size
tool that meets the demand," he explains. "There are open areas
in many places all along the East Coast where the public
infrastructure is just not there. And if the sewer is more than
about a mile away, it just does not make sense cost-wise
— it will be very expensive to put 15 or 20 homes and
then expect the sewer to come there. So that's where we come
and offer the solutions, and it becomes cost-effective to
protect the public health and protect the environment."
For an in-depth look at alternative on-site systems and
technologies, check out Anish Jantrania's 2006 book, Advanced
Onsite Wastewater Systems Technologies ($97.95; CRC Press).
Preview it on
Google
Books or purchase it on
Amazon.com.
