Maine Passive House, Part 2:
Airtight Junctions: Wall Base and Wall Top ~
But what about the joint where the base of the wall meets the
foundation? That’s always a head-scratcher for builders. Here
again, Corson’s method is to use 3M tape. The mat slab
foundation for the house, poured inside a foot-thick polystyrene
insulating form, was placed on top of a continuous sheet of heavy
clear poly, extending well past the perimeter of the slab. Once the
first-floor walls were sheathed, crew member Donny Gummow carefully
taped the poly to the OSB at the base of the wall (below). Next,
the plan is to cut the poly back within a few inches of the house
perimeter, fold it up onto the base of the wall, and tape it
again.
The wall is designed to be vapor-open throughout, says Corson.
“The dew point location within the wall moves around from
week to week and from season to season,” he says. “We
don’t want to trap moisture anywhere in the wall — we
need it to be able to dry in both directions. So at the base of the
wall, we’re not folding the plastic up enough to stop the
wall from drying to the outside. It’s just enough to air-seal
the sole plate joint to the foundation. But now I don’t have
to worry anymore about air leakage at that joint – I’m
not caulking the plate to the sill or anything like that.
It’s just sill sealer and anchor bolts.”
Where the wall frame meets the roof frame at the top of the
wall, Corson’s method is to connect the OSB wall sheathing to
an OSB skin applied to the underside of the roof trusses. Achieving
this means thinking ahead: after framing the walls but before
setting the trusses, Corson packed out the top plate with narrow
OSB strips, to make air-sealing of this juncture easier and more
fool-proof. Then he placed Grace Vycor flashing tape over the
OSB-padded wall plate (see photo below). After setting the trusses,
the plan is to attach a continuous OSB ceiling to the underside of
the trusses, seal the extended flap of pre-installed Vycor to the
underside of the ceiling OSB, and seal all the interior ceiling
joints and nail penetrations with more Vycor or 3M tape. This
tape-sealed OSB skin — which extends up the outboard face of
the 2x4 frame, then along the underside face of the roof truss
system — will define the air-tight envelope of the home,
buried well inside the insulated outer framing.
For the framers, it’s an unusual blending of framing and
air-sealing into one process — strikingly different from the
more common practice in production homebuilding, where framing
comes first and air-sealing comes later (if at all). The process is
tricky to manage. But Corson says, “It’s really easier
than doing all the framing first and the air-sealing later.”
When the goal is to achieve the very strict air-tightness spec of
the PassivHaus standard, he says, sealing while you frame is
ultimately less labor-intensive and more effective.
