Maine Passive House: Windows and Blower Door ~
Work continued in October on the Passive House project in Knox,
Maine, under construction by Chris Corson and EcoCor Builders. This
month saw the installation of the home’s high-tech
Intus windows,
manufactured in Lithuania.
Given the Passive House standard’s strict energy
efficiency requirements and detailed modeling, window energy
performance is a big deal for this project. “The windows are
important not only from an air-tightness standpoint, but also from
a thermal resistance or conductivity standpoint, and also for their
solar heat gain, generating actual BTUs,” said Corson.
“And the biggest thing is the comfort standard. These windows
with these high R-values allow for there to never be a fluctuation
of more than 3 degrees Celsius, or like 7 degrees Fahrenheit,
between the ambient temperature and the surface temperature of the
window itself.”
Window unit thermal resistance (R-value) or emissivity (U-value)
has its own Passive House standard, Corson says: “In order to
meet the Passive House standard for windows, the window has to be
less than or equal to .5 watts per meter squared Kelvin, so
that’s equivalent to a whole window U-value of about 0.14.
Now if you have windows that don’t quite meet those criteria,
you can still have a Passive House. But then you would have to
address the windows in a traditional manner — like
supplementing point-source heating underneath windows to combat
condensation. And it would definitely increase the potential for
convective current to occur because of temperature differentials,
not because of air leakage. But you could actually build a Passive
House with windows that performed slightly worse than
that.”
Corson’s Intus windows could pass the Passive House window
standard, says Corson, but they haven’t been formally
certified by the Passive House program. That’s by
Corson’s deliberate choice, he says: official Passive House
testing costs money and adds to a window’s price tag.
“I chose a window where I could get the values for the
metrics of the spacers, the frame, and the glass separately and
just do the math. And by those calculations, they’re right on
the cusp — exactly .14 U-value.”
Corson is now a U.S. product rep for Intus windows, after
meeting the company at last year’s Northeast Sustainable
Energy Association (
NESEA)
conference in Boston. “I was specifically shopping for
windows for this project,” he says. “I was looking for
a European-made U-PVC window that had the values that I needed and
was relatively green, without paying an arm and a leg. There were
some companies that met those criteria, but not to the level that
Intus did — and their price point jibed with my business
model, which is making Passive House affordable, by building these
homes at such a price point that it’s almost stupid to not
build one. That seems to dovetail with their goal of bringing
Passive House windows to a market that isn’t million-dollar
or half-million-dollar build outs, like some of these other Passive
Houses that have been built already. It kind of fit with what I was
doing.”
Window characteristics aside, installation is also a critical
part of the process. Before setting the windows (a major feat of
strength in itself, given that the 7-foot by 6-foot triple-glazed
units with one large operating pane weigh upwards of 350 lbs.
apiece), the crew installed Vycor modified-bitumen flashing tape on
the interior windowsills, and 3M tape on the exterior sills, for
water management purposes, lapping the outboard edges of the tape
over the home’s Tyvek drainage plane. And after screwing the
windows to their rough openings (Intus windows install with metal
brackets, not with a window flange), the crew took extreme measures
to make sure that the window perimeter was tightly air-sealed,
using expanding injected foam insulation as well as 3M construction
tape to seal the joints.
By now, the house is taped up like a Christmas present from a
compulsive mother: tape on every wall sheathing joint, tape between
the frame and the foundation, tape where the walls meet the
second-story ceilings, and tape on the underside of the ceilings
themselves.
But the results paid off this Monday, when a third-party
verifier arrived to test the shell’s air-tightness using a
blower door. The Passive House airtightness spec is the tightest in
the industry: 0.6 air changes per hour at 50 Pascals of pressure.
“With just the shell, no insulation, and conservative volume
calculations — although I did measure everything pretty
precisely — we are at .545 without any cellulose or
anything,” Corson reported jubilantly. “Just the
OSB.” Clearing the bar at this stage means that the
additional value of dense-blown cellulose in the cavities on both
sides of the OSB air barrier will be just icing on the cake.
“We were running around to chase leaks, but there was no
place to find the leaks,” Corson says. “The windows
aren’t leaking, nothing’s leaking. I really think half
of the measured leakage was the blower door. There were more gaps
around the blower door than there were in the rest of the house.
And this is just the rough shell. After we blow cellulose in all
the bays, and drywall and tape and caulk and mud everything, we
should be about as tight as it gets.”
