Project Profile: A Rhode Island Timber Frame Cottage
Builder Andrew Baer and his wife and business partner, architect
Meghan Moynihan, picked a tough time to open a new design-build
construction business in coastal Rhode Island in 2008. But the
pair’s young business,
Oyster Works, is
succeeding well so far in the design-build niche, based on the
company’s strong capabilities for integrating full-service
design with full-service construction management and quality
control. A case in point: this
timber-frame
cottage in a hurricane and flood zone, seaward of U.S. Route 1
on a coastal salt pond in Charlestown, R.I.
The company tore down an existing older ranch house on the site,
which would not have met modern energy or wind codes even with
significant upgrades. They saved the existing concrete foundation
— but had to elevate the new first floor by about 3 feet in
order to get the first occupied floor above the location’s
Base Flood Elevation (BFE).
The new structure, a custom-cut timber frame clad with SIP
panels, boasts high energy efficiency as well as a whole new level
of style. A structural engineering analysis, required for a permit
in the 120-mph design wind speed zone on the ocean side of Route 1
in Rhode Island, showed the timber frame was more than able to
handle a hurricane. But bringing the wind load path down to the
foundation through the new cripple wall system took some thought
and some care.
A triple 2x10 sill plate set on the foundation sill is tied to
the concrete with half-inch threaded rod anchor bolts at 4’
o.c., drilled into the wall and set in epoxy adhesive, Baer
explained. “First we had an engineer look at the foundation
and make sure that is was good,” he says. “But then,
because it’s a timber-frame building, which is a point-loaded
structure, everywhere underneath where all of the posts would be,
we placed a quadruple 2x10 post. And that quadruple 2x10 is
separately anchored down into the foundation with threaded rod and
a hold-down.”
A wood I-joist floor deck was framed on top of this cripple wall
for the first occupied floor, Baer goes on. But the posts for the
timber frame extend down through this floor system and rest
directly on the cripple wall, directly above the four-banger posts.
(The photo above shows the holes in the deck to receive the timber
posts.)
More steel connectors were needed to continue the uplift load
path for the structure: steel connectors at 2’ o.c. anchor
the engineered rim board to the cripple wall, and 2-foot steel
straps secured the timber posts to the cripple wall posts. In
addition, steel straps spanned any joint between posts and beams up
the whole height of the wall, from sill to eave. “The whole
thing is positively tied into the foundation,” says Baer
The SIP panels were curtainwall only, Baer explains — they
weren’t considered in the wind resistance of the whole house,
even though they probably do add some stiffness to the structure.
“We didn’t look at the SIPs as contributing to the
shear strength,” says Baer. “That shear strength is
actually supplied by the diagonal bracing. We had a structural
engineer analyze that, of course — in the 120-mph wind zone,
you can just say you think it’s going to work.”
