When you hear the term security system, you're apt to think
"burglar alarms," and that's the extent of what most homes have.
But if you're building a coastal resort home that will be
unoccupied much of the year, you may want to consider some added
protection. Installing systems to protect the home against fire and
flooding using the best technology the budget will allow could make
the difference between a minor incident and a major catastrophe.
That was the lesson learned in Massachusetts after a devastating
fire ravaged a one-of-a-kind 19th-century seaside home. When the
owners made the decision to rebuild, they included state-of-the-art
systems to safeguard their investment.
Return to Glory… Then
disaster
The Corbin-Norton House is the grandest of a cluster of
Victorian-era summer homes encircling scenic Ocean Park in the
heart of Oak Bluffs, one of the six towns on the island of Martha's
Vineyard. When software entrepreneur Peter Norton bought the home
in 1991, neglect and a series of remodeling nightmares had erased
much of its original look, but he was determined to restore the
house to its former grandeur. Architect Christopher Dallmus of
Design Associates in Boston worked with local contractor Neal
Galligan, president of Doyle Construction in West Tisbury, Mass.,
to return the house to its glory days. The completed project was an
exact replica of the house as it stood in 1891. "The Corbin-Norton
House stands out among all restorative renovations I've worked on
because the result was largely museum quality," says Dallmus.
Then disaster struck. In February 2001 a short circuit in an
electrical wire set off a blaze that reduced the unoccupied home to
cinders. The home's smoke detectors malfunctioned, letting the fire
quietly smolder in one room for approximately four hours, until it
got hot enough to melt the windows. When that happened, the rush of
oxygen caused the room to burst into flames, which then spread
quickly throughout the house. Firefighters made a heroic effort to
keep the fire from spreading to adjacent homes, but that was the
best they could hope for. The blaze was unstoppable.
Without hesitation, Peter Norton decided to rebuild. Galligan's
crew completed the second Corbin-Norton House in the fall of 2004.
The new incarnation is identical to the original except for one big
difference: It now includes the ultimate in burglar and fire
protection, including a commercial-grade sprinkler system.
Fire Prevention
Black Lab Alarm of Woburn, Mass., installed the home's alarm
systems. (It wasn't the same company that installed the faulty fire
alarms in the first house.) The rebuilt Corbin-Norton House is now
guarded by a Napco Gemini 9600 combination burglar and fire alarm
system. The system is continuously monitored by a communications
center that contacts the caretaker, along with the police or fire
department, whenever an alarm goes off. The alarms connect to the
monitoring service via the phone line, but the system also includes
a long-range radio backup — a must in remote areas.
As required by code, the house has smoke detectors in every one of
its eight bedrooms, at the top and bottom of each staircase, and
within 10 feet of every bedroom. But while code-mandated smoke
detectors are placed to protect people, Black Lab President Todd
Broyard says that the Nortons wanted a system that would protect
the home as well. The first step toward reaching this goal was to
install heat detectors near all mechanical equipment: in the
basement, the kitchen, the garage, and in a mechanical room in the
third-floor attic. All the heat detectors except those in the attic
will set off the alarm system when the temperature reaches
135°F. In the attic, which tends to be hotter than the rest of
the house, the system reacts to temperatures of 200°F or
higher.
Although heat detectors aren't required by code, Broyard says that
they will provide extra insurance against another devastating
blaze. "Just satisfying the fire department's requirement is not
enough," he explains. "Heat detectors are an important part of
protecting the property. One of the best things you can do is to
install them over any mechanical equipment."
Water, Water Everywhere
Detecting a fire is one thing; actually stopping a fire is another.
The Nortons wanted to make sure that the house would never succumb
to fire again, so they decided to include a sprinkler system in the
rebuild. That alone put them in a minority of homeowners. "Builders
tend to avoid including sprinkler systems in homes because of the
expense," notes David Smith of HFP Corporation in Westfield, Mass.,
who installed the Nortons' sprinkler system. But the cost wasn't an
issue on this job. While most people balk at the $7,500 it usually
costs to put sprinklers in a house this size, the Nortons didn't
hesitate to spend $50,000 for a commercial-grade system that would
make their historic property virtually fireproof.
One feature that makes the system so effective is the number of
sprinkler heads. In most single-family residences that have
sprinkler systems, the heads are positioned to allow safe pathways
out of the house. But if you want to protect the structure itself,
too, you need enough heads to quickly douse a fire anywhere in the
house.
The new Corbin-Norton home seems to have sprinkler heads
everywhere. That includes the attic, closets, and other combustible
concealed spaces. Smith's crew even installed sprinkler heads in
the ceiling of the exterior porches, as well as in the garage. The
sprinkler heads inside the house are continually charged with water
pressure, but the exterior heads remain dry until activated. The
pipes that feed them are filled with compressed air, which keeps
water out of the pipes by holding an interior valve closed. When
fire causes a sprinkler head to open, the air pressure is relieved
and water instantly rushes to the head from inside the house.
According to Smith, architects tend to worry that sprinkler heads
will detract from a home's aesthetics, but he says that doesn't
have to be the case. The sprinkler heads in the Corbin-Norton home
are flat disks that fit flush against the ceiling, dropping down
only when activated. In rooms with painted ceilings, the disks are
linen white. Unlacquered copper covers are used in rooms with wood
ceilings. Unless you're looking for them, you really don't notice
the sprinklers at all.
Shortly after the renovation of the Corbin-Norton House on
Martha's Vineyard, a fire sparked by an electrical short circuit
reduced the unoccupied home to cinders. Faced with the ruin of the
once-grand Victorian, its owner decided to restore it immediately
— adding a state-of-the-art fire and security system in the
rebuild.
Burglar Alarms
The home's burglar alarms were less complicated than the fire
protection system. At a cost of around $20,000, the security system
is in the average price range for homes this size, notes Broyard.
It protects the home against unwanted visitors with magnetic
contacts on all doors and windows, plus motion detectors in central
areas.
Although the Corbin-Norton House doesn't have remote video
surveillance, Broyard says that this technology is becoming popular
with owners of second homes. Such systems consist of cameras tied
into a digital video recorder that the owners can monitor remotely
from their primary residence. Besides providing security, they also
have a spy function: Owners have been known to use them to check on
the comings and goings of everyone from work crews to the meter
reader. "At the very least, these systems can help you keep tabs on
your caretaker," says Broyard. "About half the owners of summer
homes are now opting for surveillance systems."
The Nortons invested in a commercial-grade sprinkler system
(above) capable of feeding a large number of sprinkler heads
distributed throughout the interior and exterior of the
house.
SPRINKLER & SMOKE DETECTOR
A complete fire system in the Corbin-Norton house includes not only
discrete sprinkler heads (top left) and smoke alarms (top right),
but also heat detectors (above right). These heat detectors were
installed in the kitchen (between lights above left) as well as in
the basement, the garage, and in a mechanical room in the
third-floor attic.
Other Systems
The Corbin-Norton House includes another alarm system that's a good
investment for any vacation home in the Northeast: a freeze alarm
to signal a burst pipe in the wintertime when the home is
unoccupied. The alarm can be set to alert the monitoring service
when temperatures in the home fall below a certain level. Flood
detectors in the basement complete the home's environmental
protection system. "Low-temperature alarms are very important in
summer homes," notes Broyard. Unless the owner plans to have the
pipes drained seasonally, a freeze-alert system is all but
indispensable to protect a house from what can be a very expensive
situation. "Almost all second homes I work on have these," he
says.
Of course, most second homes don't get nearly the amount of
protection that went into the new Corbin-Norton House. But you
don't have to be working on a historic mansion to realize that true
security goes beyond simple alarms. A live-in caretaker may be the
ideal, but barring that, monitoring systems that alert a
communications center and on-site systems that protect the home
itself may be a good investment.
Charles Wardell writes on construction topics from Vineyard
Haven, Mass.
