Every year at this time, JLC editors sort
through piles of press releases and swarms of e-mails to round
up a batch of building products — tools, materials,
fixtures, fasteners — that we think will help you work
faster and better. This year, we’re doing something a
little different: focusing on products we discovered while
walking the floor at JLC Live in Providence, R.I., in
March. The sluggish economy notwithstanding, the exhibition
hall was full, with manufacturers and suppliers of all stripes
seizing the opportunity to reach the JLC audience.
Here’s a small sampling of what we found.
Something New, Something
Blue
The sight of Bosch framing nailers must have turned a few
heads at this year’s show. According to the toolmaker,
the line of pneumatic nailers has been in development for
several years, with thousands of hours spent field-testing and
gathering feedback from users across the country. Bosch has
introduced two framing guns — the SN350-20F full-head
(1) and the SN350-34C clipped-head —
with a roofing nailer, several finish guns, and a line of
compressors to follow.
The air chambers on the framing nailers are designed with
something Bosch calls “full force technology,”
meaning that every bit of the air coming from the compressor is
used to drive the fastener. Early reports from the field
indicate that, indeed, the guns have plenty of power. Bosch
also claims to have delivered this performance in a tool
that’s smaller than comparable nailers, for better
maneuverability. At 8.4 pounds, these guns are not particularly
light, though they aren’t the heaviest out there,
either.
Notable features include a rugged strike plate on the back for
positioning framing (2), a spiked nose for
toenailing (3), and an optional rafter hook
(4) that can be picked up at stocking dealers
for around $20. The guns are currently available online for
around $300 each. Contact Bosch Tools at
boschtools.com or
877/267-2499.
The Moment Has Come
The folks at Simpson Strong-Tie — the connector company
— have done it again. This time they’ve packaged up
the steel moment frame for delivery to your site, where it can
be assembled by your crew using nuts and bolts
(1). Custom builders in seismic and high-wind
zones are used to dealing with lateral loads — in homes
with walls of windows intended to take in the view
(2), for example, or large garage openings.
Steel is a tried and tested solution, but it’s typically
meant that you had to plan for custom fabrication and schedule
a welder to visit the site, not to mention enlist an engineer
to do the design work. With the Strong Frame, the entire
process is a lot easier. For one, everything’s
pre-engineered to meet wind and seismic codes, including the
foundation anchors, which are located with templates for
accuracy. Frames are available in seven heights from 8 to 19
feet, and in four widths from 8 feet 2 inches to 16 feet 4
inches. You use ordinary wrenches to assemble the frame;
squeeze-out from special washers loaded with orange silicone
allows you to see when the nuts are properly tightened
(3, 4). The frames come prepunched for wiring
and mechanicals, and wood nailers are already attached, making
it easy to tie the moment frame into the surrounding wood
framing (5). Prices for the Strong Frame range
from $3,000 to $10,000; contractor pricing may vary. Visit
strongtie.com for design
and installation instructions or to find a dealer.
Quick Concealed Fastening
Known for a decade for its reliable line of structural screws,
FastenMaster recently introduced the Cortex concealed fastening
system, designed specifically for composite decking and
cellular PVC trim (1). The corrosion-resistant
2 3/4-inch-long Cortex screw is driven into the trim or decking
using the setting tool (2), which disengages
automatically when the screw head is at the correct depth
beneath the surface. This leaves a neatly formed plug hole that
is filled with provided plugs matching the trim or deck
material (3). Currently FastenMaster has plugs
to match Azek Trim, Azek Deck, EverGrain Classic Decking,
TimberTech TwinFinish, Trex Accents, and Trex Escapes. A box of
fasteners and plugs good for 250 lineal feet of trim costs
$111; screws and plugs for 100 square feet of deck cost $98.
For more information or to order, go to
fastenmaster.com or
call 800/518-3569.
Traction on the Roof
Titanium UDL-30 Synthetic Roofing Underlayment has an
impressive set of specs: It’s 25 mils thick but weighs
only 4 pounds a square; it has passed a nail sealability test
usually applied to peel-and-stick membranes; and it’s
warrantied for six months against UV damage. Verifying all of
that would be hard, but the stuff sure makes a strong
impression in person. Not only does its raised-grid surface
grip the foot, but it’s extremely resistant to tearing
and comes in a pleasing light-gray color — easier on the
eyes and less likely to heat up than the typical black
underlayment. UDL-30 should be fastened with 1-inch plastic
caps. It costs around $140 per square. Go to
interwrap.com or call
888/713-7663 for further details.
Pro-Quality Foam Gun
Drumroll, please: Though it’s never had the largest and
certainly not the loudest booth, EFI — Energy Federation
Inc. — has been an exhibitor at every East Coast JLC Live
since the show’s humble beginnings in 1995, when a few
vendors set up their literature on folding tables in a narrow
hotel banquet room in Cambridge, Mass. This year, the
company’s line of products — anything and
everything intended to make homes tighter, better ventilated,
more resource-efficient — is more broadly relevant than
ever. If you haven’t visited EFI’s Web site, check
it out: efi.org. And if
you’re still using those 12-ounce cans of spray foam with
the straw attached for your air-sealing efforts, maybe
now’s the time to get a pro-duty tool. EFI’s
starter kit, which includes a rugged Pageris gun, two 33-ounce
cans of low-expansion foam, 10 nozzle tips, cleaner, and a
case, sells for $169; call 800/876-0660 to order.
Preassembled Radiant Panels
With its HydroNex arrays (1), Watts Radiant
is aiming to take some of the technical head-scratching out of
installation and servicing of radiant heating systems —
plus spare you the long, costly hours of pipe layout, joint
sweating, and electronic wiring. The company has preassembled
control, pumping, and mixing components onto panels designed to
literally plug in between the heat source and the distribution
piping. Main functions have been isolated onto four types of
panels: primary circulation panels, with reset controls and
manual or auto-refill (2); distribution
panels, which use a variety of components — depending on
customer preference — to provide high, mixed, or
variable-mixed supply temperatures (3);
specialized panels designed for unique heat sources, like solar
or geothermal (4); and zone panels, built with
manifolds and designed to be located in the zone served.
Systems can range from basic to complex and everything in
between; the beauty of the approach is that the many components
have been preselected, presized, and prearranged into
functioning, tested assemblies — the kind of installation
that might make your plumber really happy and give your
customer a system that can be serviced and supported for the
long haul. According to Rich McNally of Watts Radiant, pricing
for panels can be obtained through distributors. Visit
wattsradiant.com/professional/hydronex.asp for more
information.
Thinset Shower Pan
Attention tile-setters: If you’ve considered using a
thinset shower pan liner but prefer to use a weep drain, you
may want to try the ProBase from Noble Co.
(1). It’s a presloped composite plastic
base with a waterproof membrane laminated to the top. The base
gets bonded to the substrate with modified thinset. A
depression in the middle (2) allows the
membrane to be clamped to the bottom half of the weep drain
(3), which is waterproofed with a bead of
NobleSealant 150. The height of the upper part of the drain is
set according to tile thickness, and the depression is filled
in with sloped mortar. A strip of NobleSeal TS membrane is
applied around the base of the walls, to a height of about 12
inches (4). Corners are sealed with preformed
inside and outside membrane corners bedded in NobleSealant 150
(5).
A 48-by-48-inch ProBase kit costs around $500; it includes the
base, four preformed inside and four outside corners, membrane
for the inside wall perimeter, a tube of NobleSealant 150, and
a plastic shield for covering the drain while placing the
mortar around it. Visit
noblecompany.com for
complete installation instructions and an installation
video.
Narrow Shear Braces
Anytime you put two 9-foot-wide garage doors in the end of a
24-foot-wide building, you’ve got a potentially weak
structure, especially if you build in a coastal wind zone. The
three remaining 2-foot wall sections don’t give you
enough length to provide reliable bracing with structural
sheathing — at least the way sheathing is typically
nailed. One remedy is to apply the “alternate braced wall
panel” method found in the IRC (R602.10.6). A simpler way
is to use a Shear Brace from iLevel. Made from 3 1/2-inch-thick
TimberStrand, the braces come in 12-, 18-, and 24-inch widths,
and heights of 7 to 13 feet for standard wall framing and up to
20 feet for tall walls. The product is sold in three formats:
standard, for a single story; stackable, for multistory
applications; and portal. Pricing varies, but a single panel
for a standard one-story application (including the anchor kit)
costs around $500. For more information, go to
ilevel.com.
Hot Water From the Sun
Roof-mounted solar water heaters don’t always look that
good. In fact, many of them are eyesores — which helps to
explain why experienced solar thermal installers around the
country have begun to adopt the new system from Velux. Having
established its reputation as a maker of attractive, watertight
skylights, the company has turned its know-how to making solar
collectors, which — except for the hole in the roof
— are mounted and flashed much like its raised-curb
skylights (1). The collectors resemble
oversized skylights (2) and can be mulled with
skylights to good effect (3).
Velux packages the collectors with a solar water tank
(4), a pump station and controller, a mixing
valve, an air separator, an expansion tank, and propylene
glycol to charge the system. A two-collector package, adequate
for a two- to three-person household, costs around $8,000 to
$9,000 installed, says Stephen Bohner of Alchemy Construction
in Arcata, Calif. The system qualifies for the 30 percent
alternative-energy tax credit through 2016. For more
information, visit
veluxusa.com.
4
Sticking Around
When 3M — the tape people — decided to get into
the flashing-tape business, chances were good that they’d
develop a decent product. They know a lot about how to make
things stick to each other. According to Paul Engen, an
engineer in the company’s industrial tapes division, 3M
asked builders what they wanted in a flashing tape, and three
requests came up again and again: They wanted something that
was not too thick and that would stick in cold weather and to
damp surfaces. Introduced last fall, the 8067 All Weather
Flashing Tape claims to deliver on all three points. It’s
10 mils thick (compared with 25 mils for Grace Vycor Plus), can
be applied at temperatures down to 0°F (and up to
120°F), and has an acrylic adhesive formulated to
stick to a damp surface (though not a water-soaked substrate).
The product meets the AAMA 711-05 specification for
self-adhered flashing used in window installation, which
includes a nail sealability test.
If you’re looking for a single roll of tape that will
stick to a variety of common building materials — among
them poly, housewrap, aluminum, OSB, and plywood — this
may be it. The 75-foot rolls come in 4-, 6- and 9-inch widths.
Right now sales are through the Internet; a case of 12 4-inch
rolls sells for $225, or you can try a 4-inch-by-25-foot sample
roll for $6.25. To purchase, go to
shop3m.com and search on
8067. Use the code JLC at checkout for a 25 percent
discount.
