Scheduling Software 101,
continued
cPM Scheduler
CDCI
800/285-2324
www.cdci.com
$600 for up to ten concurrent projects; other pricing plans
available
Unlike the generic schedulers in this article (Project,
SureTrak, FastTrack, QuickGantt), cPM, by Construction Data
Control, Inc. (CDCI), is built to schedule one thing only:
construction. And it crosses the line between pure scheduler
and complete project management system by tracking accounting
cost codes and allowing project managers to control the
schedule from the field. cPM's only shortcoming is that, like
VirtualBoss, it can only schedule in full-day increments, which
may not be ideal for remodelers.
CDCI's cPM combines an easy-to-use
scheduler with project management tools like job to-do lists,
budget tracking, and job inspection worksheets. cPM's PDA
modules allow project managers to maintain the schedule and
approve budget items right from the field.
Only three fields of information — Activity,
Duration, and Sequence — are required to set up
complete project schedules in cPM. Each activity can be tied to
a budget item, either imported from CDCI's accounting software
or entered manually when the schedule is set up. All major
functions of the scheduler are mirrored in the PDA versions,
which will run on either PalmOS or PocketPC devices. Project
managers can manipulate the schedule, approve budget items, and
check off to-do items right from their handheld
computers.
CDCI has also realized that not all builders are ready for
PDAs. A number of useful "clipboard-friendly" reports, such as
Job Inspection Worksheets, Activity Details, and Vendor To-Do
Lists, build a bridge between the electronic world of the
construction office and the paper-based world of the typical
project manager. All reports can also be written to over a
dozen standard computer formats, including text, Excel, and
HTML, for distribution via e-mail or the Internet.
cPM is available as a stand-alone scheduler or can be combined
with CDCI's accounting software to form the field component of
a robust purchase-order and pay-from-PO system for production
builders.
BuildLinks Online
Scheduler
BuildLinks
800/803-3002
www.buildlinks.com
$75 per home scheduled, $1,000 one-time setup fee
Web services continue to peck away at the conventional
software market for good reason: There is no easier way to
share project data than to put it up on a website where anyone
with a browser can access it. The full BuildLinks system is an
"online collaboration" service with a twist: one view for the
home buyer and another for the builder. Buyers logging on to
the system are greeted by a friendly project overview, while
builders log on to track all the gory details. This two-sided
approach works well: You can show customers what they need to
know and do at all times without worrying them with unnecessary
detail. The BuildLinks Scheduler is the latest module in the
BuildLinks online system. It's available stand-alone or
integrated into the other BuildLinks project management
tools.
BuildLinks Scheduler is totally web
based but rivals conventional software. It even adds a few
tricks of its own, like automatic updating via Nextel
Blackberry pager and an unusual bubble chart (inset).
BuildLinks' familiar calendar view (in front, at bottom) makes
it easy for buyers to see selection dates and project
milestones.
Despite running in a web browser, the BuildLinks Scheduler is
conventional in approach. Tasks, resources, and dependencies
are scheduled in a list view, which automatically generates an
interactive bar graph similar to a Gantt chart, and a calendar
view. Lead and lag times are created by altering date ranges in
the list view, and the user can select whether a particular
activity will appear on the homeowner calendar, the builder
calendar, or both.
It's obvious that a lot of "builder-thought" went into the
BuildLinks Scheduler. For example, you can make a task
dependent on completion of a task in a different project, a
necessary scenario for townhouse or condo builders who are
running a separate "shell" schedule. You can also do basic
resource allocation to see where a particular sub is scheduled
across all projects. All reports can be "printed" to .PDF
files, and the system will automatically notify participants of
schedule changes by e-mail.
VirtualBoss 3.6
VirtualBoss Software
888/827-5397
www.virtualboss.net
$395
Created by a builder, VirtualBoss combines a simplified
critical path scheduler with a basic contact manager, a good
combination for hands-on contractors who don't have the time or
patience to learn more complex scheduling systems.
VirtualBoss has three basic modules: Job Manager, Task
Manager, and Contact Manager. The scheduler itself is very
basic. Everything is lumped together in a master "task list,"
which you can filter by project, by contact, or by date. You
can also create project "groups" — for instance, to
filter a list of all material deliveries, or to see all the
tasks related to a particular subdivision. Scheduling is in
full-day increments only. The start date of a task can be
linked to the completion date of a previous task to create a
basic critical path schedule, but there are no advanced
constraints, no resource leveling, and you can assign only one
contact (resource) to a task. The built-in contact manager is
adequate for looking up phone numbers on the fly and keeping
track of essential address information, but it is not very
customizable and does not log client activity, except for
e-mail.
VirtualBoss generates individual work
orders, as well as complete project lists, and delivers them to
whoever is responsible by computer fax or e-mail.
It's not the fanciest scheduler or the most versatile contact
manager, but VirtualBoss has a better trick up its sleeve
— automatic work orders. It lets you distribute task
lists and individual work orders painlessly with just a few
mouse clicks — by computer fax (Windows fax drivers or
WinFax Pro required) or e-mail — to whoever needs to
see them.
The VirtualBoss interface is simplicity
itself: a window for setting up projects, another for setting
up contacts (resources), and two task views, a list and a Gantt
chart.
VirtualBoss is all about ease of use, and I can envision even
computer greenhorns having no trouble riding around with
VirtualBoss on a laptop computer, scheduling and tracking their
projects, and using the program to send work orders right from
the job site. A PocketPC companion version is also available
($60), and PalmOS PDA users can get information in and out of
VirtualBoss by using a third-party utility like Documents To Go
(www.dataviz.com).
QuickGantt Plus 4.0
Ballantine & Company, Inc.
800/536-6677
www.tools-for-business.com
$249 for single-user license; other versions start at
$99
If all you want is very basic list-based scheduling with
at-a-glance visuals, QuickGantt Plus might be just what the
doctor ordered. It hasn't changed much since we reviewed it in
1998 (Computer
Solutions, 9/98). The interface features three tabbed
views: Worksheet, which is similar to an Excel worksheet, Gantt
Chart, and Notes. You won't find PERT charts, resource
leveling, or Internet-based collaboration, but you will get
speed. Working in the Worksheet view, you can set up the bones
of a typical residential schedule in just a few minutes. One
nice feature is a budget column where you can plug in costs for
various line items. You can also create a "master schedule" by
grouping individual worksheets together. The result can then be
filtered by individual jobs or merged into one combined
worksheet. QuickGantt also has the ability to compare a
baseline schedule with a revised version.
QuickGantt's simple and straightforward
interface makes it possible to set up a schedule in minutes.
Worksheets can be combined to form a master schedule
(left).
QuickGantt Plus integrates with Ballantine's QuickAssist
contact manager to link to resources directly, and you can
import and export to a number of standard formats, including
Access, Excel, and comma-delimited text. Finally, in the PDA
department, a $25 add-on makes QuickGantt the least expensive
PDA-enabled scheduler in this roundup.
