Products, continued
Include the Kitchen Sink
Functioning in a home without a kitchen can raise any
homeowner's stress level, and a stressed homeowner can create
unnecessary stress for you. You can minimize your customer's
inconvenience with a Portable Kitchenette. The stainless-steel
work center gives your clients a sink and room for food
preparation in a self-contained, easy-to-clean unit. The
420-pound unit features a pullout butcher-block cutting board,
16x12-inch sink, food storage drawers, and a stainless
countertop. Removable drawers and casters make transporting
easier, and it fits in the back of a pickup. You can lease the
unit from the maker for $150 monthly or $1,500 a year, plus
shipping. Or you can buy it for $2,500, plus shipping.
Diversified Metal
510/667-9900
http://www.mobilekitchenette.com
Powerful Phone
Jack
It used to be when you wanted a phone, you simply plugged into
a jack and got a dial tone. But today's cordless phones and
answering machines require an AC outlet, limiting where you can
put the phone and tying up an outlet with a big, bulky
converter. Enter Leviton's Out-of-Sight Power Jack, a phone
jack that includes a DC power supply for cordless phones and
answering machines. The jack has six common plug adapters and
adjustable settings from 7 to 12 volts, making it compatible
with most phones, according to the manufacturer. It sells for
$20.
Leviton
800/323-8920
http://www.leviton.com
Fire
Fighter
Sensing heat instead of smoke, the new HD6135FB Heat Alarm is
suited to spaces like kitchens and garages, where traditional
smoke detectors can create nuisance alarms. The hard-wired
alarm has a 9-volt battery backup and can be interconnected
with more traditional smoke detectors. It can also be tested or
silenced with most TV remote controls. The
microprocessor-controlled alarm sounds an 85-decibel siren at
135°F or after detecting a 15-degree-per-minute
temperature rise. The alarm retails for $28.
BRK Electronics
800/323-9005
http://www.brkelectronics.com
Durable
Landscape Ties
Because they're made in large part from the plastic and
nonmetal components of recycled automobiles, XPotential
Products claims that its Impact Posts, Landscape Ties, and
Impact Curbs will last for 75 to 100 years. According to the
manufacturer, the products won't warp, split, or decay and have
twice the fastener-holding ability of comparable products. The
naturally brown material can be painted or stained, but cutting
and drilling require abrasive or carbide-tipped tools. A 4x4x8
post retails for between $9 and $11 and a 6x6x8 for between $20
and $25.
XPotential Products
800/863-6619
http://www.xpotentialproducts.com
Tailgate
Stepladder
It probably wasn't a big deal when you first started out, but
climbing into the back of your truck gets harder as time goes
by. Installing a Gate-or-Step on your truck's tailgate makes
climbing in and out of the bed a lot easier, according to the
maker. The lightweight aluminum stepladder unfolds in seconds,
features nonslip treads and quick-release pins for easy
removal, and sells for $149.
Gate-or-Step
603/624-2717
http://www.gateorstep.com
Bendable
Bit
Fishing wires is never an easy task, but having a drill bit
that bends around obstacles can make the process a little less
aggravating. Made from heat-treated spring steel, Flexible
Drill Bits are available in lengths from 2 feet to 6 feet.
After drilling, the wire can be tied on to the bit through a
small hole and pulled back through the opening. Sizes from 1/4
inch to 3/4 inch are available in auger, twist, and masonry
styles. Prices run from $23 to $40.
Ideal
800/435-0705
http://www.idealindustries.com
Big
Router
Because large routers are frequently used with a router table,
Milwaukee has added some cool, ease-of-use features to its
5625-20 Fixed-Base Router. The variable-speed (10,000- to
22,000-rpm) 3 1/2-horsepower router has a 15-amp motor and
feedback circuitry for consistent speed and power. Depth
adjustment can be made from above the table by inserting the
included T- handled wrench through the router's base. The
design eliminates reaching under the table to adjust bit
height. A coarse setting adjusts the bit to within 1/8 inch,
and a micro-fine adjusting knob can fine-tune the setting to
1/64 of an inch. The street price is $295.
Milwaukee
877/729-3878
http://www.mil-electrictool.com
Problem-Solving
Post Cover
Promising an end to painting and the elimination of checked
and cracked 6x6 posts, the Sheerline PVC post system slips over
an ordinary pressure-treated wood post to provide a durable,
attractive, and maintenance-free finish. A matching aluminum
base for mounting on concrete is also available, along with
matching caps. Covering a post requires four individual pieces,
which are sold in 8 1/2-foot and 10-foot lengths. An 8 1/2-foot
post costs about $52 to cover, a 10-foot post about $60.
L.B. Plastics
800/752-7739
http://www.lbplastics.com
Moldable
Molding
While increasingly popular, curved walls and architectural
elements make installing trim a challenge. But Style Solution's
new polyurethane Flexible Moulding makes curved work easier.
Designed to match most popular molding profiles, the new line
can be flexed to fit both inside and outside curves and can be
bent in a compound radius, like curved stairways. According to
the manufacturer, the product has greater flexibility than
flexible vinyl moldings, and the factory-applied primer won't
peel when flexed. According to the maker, pricing is similar to
that of vinyl-based flexible moldings.
Style Solutions
800/446-3040
http://www.stylesolutionsinc.com
Access
Insulator
The Department of Energy cites the common pull-down attic
access as one of the biggest energy wasters in most homes.
Seven states now require insulation on the opening in an effort
to reduce heating and cooling losses. The Draft Cap, a
polystyrene dome, covers the top of the attic access and
insulates it with an R-12 rating. The lightweight cap installs
without assembly and costs $100.
Draft Cap
888/292-2229
http://www.draftcap.com
Boot
Dryer
Outdoor work is one of the realities of building or
remodeling, even when the weather is uncooperative. When nasty
weather soaks your shoes and gloves, the Dry-Doc can help. By
circulating air through multiple ports, the Dry-Doc dries your
gear without damaging heat, while an integral Drip Lip tray
catches slush and run off, preventing a wet mess in your house.
With a handy seat on top for lacing up, the Dry-Doc will dry
out gloves and boots within hours. The AC-powered unit sells
for $50.
SMC Innovations
866/450-0200
http://www.dry-doc.com
Faster Sink
Installations
Offering the lowest installed cost, drop-in stainless sinks
are the most popular option for multifamily and low-cost
construction projects. But squeezing under the sink to tighten
down those annoying clips is a chore that every installer would
happily avoid. The new Quick-Clip fastening system installs
from the top, making installation faster and easier. Available
on Elkay's Lustertone line of sinks, the product is ideal for
multiple sink installations and installs in half the time of a
conventional system, according to the maker. An 8-inch-deep
double bowl lists for $585.
Elkay
630/572-3192
http://www.elkay.com
