Americans love capes, saltboxes, and other
“traditional” house types. At the same time, very
few of them want to live a colonial lifestyle. Today’s
home buyers demand more open, interconnected spaces than the
spaces found in authentically traditional houses. As an
architect friend of mine likes to say, Americans really want
“contempolonials” — houses that are
traditional on the outside but contemporary on the inside. This
conflict affects the design process in a number of ways; one of
the most apparent has to do with window placements as seen from
outside the home.
Conflict Between Front and
Rear
If the client wants a traditional centered home shape, the
facade that faces the street typically has the expected
symmetrical window layout (see Figure 1). But almost
invariably, the perfectly centered street-facing windows give
way to more eccentric placements at the sides and rear, where
large areas may have no glass (think closets, mechanical
spaces, food storage, and major appliances), while other areas,
such as family rooms and master bedrooms, often give themselves
completely over to glass (Figure 2). The result is a visual
disconnect between the home’s classically centered public
face and the less orderly arrangement of windows at the rear,
which is determined by what’s going on within the
exterior walls rather than a desire for symmetry.
Figure 1.This sort of symmetrical front elevation
worked well in the 1800s, and it’s a look that remains
popular today. Window layout provides few problems, as long as
the street-facing walls of the front rooms are free of
window-obstructing interior elements.
Figure 2.The historically authentic rear elevation
of the same saltbox-style house, on the other hand, is poorly
adapted to modern lifestyles (left). Today’s version is
more likely to look like the drawing at right. The increased
glass area makes for a brighter interior, but laying out
windows around appliances, closets, and other obstructions
results in an awkward-looking, unbalanced
elevation.
The Horizontal Connection
Fortunately, there are ways to reconcile these competing
interests. One approach — often seen in Arts and Crafts,
Victorian, and shingle-style houses — is to set up a
dominant horizontal line that serves to unify otherwise
scattered window placements. A trim profile that stands several
inches clear of the wall, for example, can add a strong visual
element that prevents variations in the sizes, shapes, and
orientations of adjacent windows from appearing chaotic (Figure
3). Another nice way to incorporate windows into the overall
house shape is to make window heads marry with the soffits or
fascia at the eaves, thus making a real sense of the
“top” of a house. Careful layout and planning are
key.
Figure 3.While not perfectly symmetrical, the
window placements on the shingle-style house above have a
pleasing balance. The windows below the gable peaks are focal
points that provide a feeling of “centeredness.”
The irregularly spaced windows in the side elevation (right)
are visually unified by the use of a strong eaves line and a
flared belt course midway up the wall.
Balance, Consistency, and
Trim
A nonsymmetrical window layout can sometimes be balanced by
using a door or pair of doors as a visual “pivot
point.” As long as the windows are arranged in a simple,
regular pattern, they don’t need to be centered on a
facade to provide a sense of overall consistency (Figure
4).
Figure 4.The symmetrical arrangement of windows in
the gable-end portion of this beach-front house is accented by
the nonsymmetrical but balanced layout on the wing at left.
Grouping windows around the glass doors in the wing provides a
strong focal point that acts as a visual counterweight to the
expanse of glass at far left.
The windows themselves are another important factor. If the
general window type used throughout a given house — such
as 6-over-1 double-hungs, cottage-style windows, or fully
muntined panes — is rigorously consistent, variations in
size and location of the windows become much less
distracting.
Finally, have some fun with trim. Playful elements like
shutters, flower boxes, and expressed rooflets over the tops of
windows can be used as “eye candy” to provide depth
and sustain interest. These sorts of elements can also
reinforce a focal point created by a window at a front door or
at the top of a gable (Figure 5).
Figure 5.An ornamented peak and projecting
“rooflet” over the stacked windows adds a sense of
unity to a side elevation that might otherwise seem
disorganized and chaotic.
Duo Dickinsonis an
architect in Madison, Conn.
