Perhaps because they're small, entry foyers are often designed
with little thought. That's a mistake, because a foyer has an
important effect on how a visitor or homeowner feels about the
rest of the house. Instead of seeing it simply as a small space
for greeting guests and storing coats and boots, try thinking
of the foyer as the introductory chapter of a good book —
a well-thought-out space that sets the stage for what lies
ahead, without giving away the story.
Sight Lines and Light
A set of plans that we recently revised for one of our clients
provides a good case in point. The original plans featured a
two-story glass entry (see Figure 1). It's a common feature
among recently built homes — especially where the
homeowner's real entry is the door leading from the garage to
the kitchen — but the result can be cold and
uninviting.
Figure
1. In the original plan, the exaggerated scale of the
entry and the absence of any outdoor transition space leads to
an "abrupt" feel that is not at all welcoming (top). Inside,
the two-story foyer had additional problems (above), including
uncomfortably exposed second-floor bedrooms, a poorly defined
living room, and a direct sight line to the dirty dishes in the
kitchen sink.Pajamas on parade. The original design also
made the classic mistake of mixing the home's private spaces
with its more public ones. As drawn, the main stairs led up to
a second-floor hallway, separated from the foyer below by only
an open railing. Every trip between one of the upstairs
bedrooms and the bathroom down the hall would have taken place
in full view of anyone standing in the foyer.
On the lower level, there was no clear boundary between
foyer and living room, so neither space appeared to have a
clearly defined purpose. Rather than emphasizing the fireplace
— which should have been a natural focal point —
the sight line from foyer to living room led to a window at its
far end, which offered a view of the blank sidewall of the
neighbor's house.
A Made-Over Foyer
Our first step was to replace the original grand entry with a
modest porch, so a visitor waiting for an answer to the
doorbell wouldn't have to stand out in the rain (Figure 2).
That also cut down on the amount of daylight reaching the foyer
itself, to good effect: Because people are instinctively
attracted to light, the subdued lighting gave the well-lit
spaces beyond a more welcoming feel. That would have been
impossible to achieve in a foyer already awash with direct
sun.
Figure
2. The author replaced the oversized glass entry with a
simple porch, providing a sheltered place to ring the doorbell
or fumble with house keys (top). The human-scale entry is more
inviting and doesn't flood the foyer with too much daylight. On
the inside, the redesigned one-story foyer has a more
comfortable feel, improved sight lines, and makes more
efficient use of space (above).
To visually separate the living room from the foyer, we
added a set of French doors flanked by a pair of closets.
Moving the fireplace from its original location between the
living room and dining room to the far end of the living room
was helpful in two respects. First, it made for a more balanced
front elevation, by using the mass of the exterior chimney to
offset the garage at the other end of the house. Second, it
shifted the fireplace to the far end of the living room, where
it provided a strong visual anchor to the view from the foyer.
(An exterior chimney is admittedly more expensive and less
energy-efficient than one located inside the building envelope,
but visual gains in this case made the trade-off seem
worthwhile.)
Varying ceilings heights. We enclosed the
redesigned foyer with an 8-foot ceiling to make the upstairs
into a purely private space. Dropping the ceiling to 7 feet in
the passage from foyer to kitchen — and casing the far
end of the opening — gave each area a separate feel,
without restricting movement between them. Lowering a ceiling
in a transition space also has the effect of making the space
beyond seem more spacious than it otherwise would.
Alan Freysinger is an
architectural designer and co-owner of Design Group Three in
Milwaukee, Wisc.
