Precise planning and workmanship at every stage of work
ensures a trouble-free job
by Paul and Kathy
McLellan
We run a family-owned custom glazing business on Cape Cod in
Massachusetts. One of the things we specialize in is the
installation of frameless shower enclosures. The high style of
a frameless glass shower enclosure also comes at a high price
— about $2,000 to $5,000 on average. A successful
installation requires a high degree of precision, and the
margin for profit is tight. If you can't complete an average
installation in a day, you're probably not going to make any
money. Perhaps this is why few glazers in our immediate area
seem to take on these jobs.
Most of our business comes by way of the homeowner, but we
also work with several custom builders on a regular basis.
These builders have become familiar with the important job-prep
requirements for a frameless enclosure, which are the focus of
this article.
Because we can give important advice to both the homeowner
and the builder, we prefer to get involved on the ground floor,
before the shower surround has been framed, boarded, and
received a finished surface, usually of marble, granite, or
solid-surface material.
Job Prep
We'll quote a job from plans or rough openings on the
assumption that the walls and floor will end up being level,
square, and true. However, we'll only proceed with an order
after taking final on-site measurements, after the finished
wall surface has been installed. If we uncover any
abnormalities, such as an out-of-plumb wall, we'll have to make
an adjustment to the price. But if we find that a supporting
wall bows in or out, the whole enclosure might need to be
redesigned. For example, we can't use wall mount hinges on a
bowed wall. The hinges must line up in a straight plane or
they'll work against each other.
Most of the problems that arise can be dealt with, but the
cost of imperfection can be significant. Once, we had to have a
newly tiled surround rebuilt when unevenly installed tiles at
the base interfered with the glass installation. So it's best
if everyone's on the same page from the start of the job.
The basic guidelines that govern a successful
installation can be quickly summarized as "plumb, level and
square." No modification will make this type of enclosure
inexpensive, but there are a few qualifiers to the guidelines
that can have an effect on the appearance and performance of
the enclosure, and on the economy of the job. The shower
threshold should be dead-level side-to-side, but have a
definite, minimum 5-degree slope to drain into the basin. It's
best if the framer establishes the slope, but the
tile-installer can always shim the threshold to compensate.
| Figure 1. Head
channel joining plates for frameless enclosures
come in fixed corners of 90- and 135-degrees
(left). Off-angles, which drive the cost of an
enclosure up, are handled with an adjustable corner
(above). The authors measure, cut, and join the
extruded header sections on site.
Angles in the enclosure work best at 90 degrees and 135
degrees, because the proprietary joining brackets come in these
fixed angles (see Figure 1). Off angles can be accommodated
with an adjustable bracket, but the level of difficulty and
therefore the cost, goes up. Likewise, glass can be cut to
conform to out-of-plumb and out-of-square conditions, but
there's a penalty in the cost of fabrication.
A neoangle surround is a popular configuration, and often
incorporates a half-height buttress wall on one or both sides
of the opening. Instead of leaving the open end of the wall
square to itself, the job comes out much nicer if the builder
defines the opening jamb with a 135-degree wall return. This
eliminates the need for a weak, narrow glass panel to make the
corner transition. Instead, the glass panel on top of the
buttress wall receives a 45-degree beveled edge that meets in
parallel with the square edge of the door (Figure 2).
Figure
2. A 135-degree return at the end of a buttress
wall makes a clean, attractive detail that simplifies
the enclosure design. A 45-degree miter on the glass
edge lines up with the wall termination, creating a
continuous interface for a square-edged door. After the
glass has been accurately dry-installed, it is marked
to facilitate repositioning after it's set in silicone
caulk. |
Design
The job begins with the design. Kathy consults with the
homeowner, the builder, and anyone else who may have input into
the appearance of the final product. Our hardware supplier,
C.R. Laurence (2503 E. Vernon Ave., Los Angeles, CA 90058;
800/421-6144; ), provides us with worksheet forms on which
Kathy records the thickness of the glass, the style and finish
of the hardware, the handle and towel bar selection, the width
of the door, and which edge seals will be used. Matching the
finish of the enclosure hardware to faucets and towel bars has
a definite effect on the quote — brushed or polished
nickel and antique gold finishes have been major factors behind
some of our most expensive units.
