Frameless Shower Installation
Continued
The glass rests on clear plastic setting blocks, which we
position over the screw heads as an extra precaution against
nicks. By using blocks of various thickness, we can perform
minor shimming adjustments to level and align panels.
Trial fitting. The panels at either side of
the door must be absolutely plumb and level to ensure that the
door will align accurately and hang in a neutral attitude.
Before we secure the panels into the channels with silicone
sealant, we test fit the enclosure several times during the
course of installation to make certain that everything aligns
exactly, and that we'll have a 1/8- to 3/16-inch gap at the
vertical edges of the door for clearance (Figure 5 and Figure
6).
| Figure
5. Trial assembly ensures that all of the
components are positioned correctly, and that the door
will operate freely, with the minimum necessary
clearance to reduce water escape (above left). With the
header secured, the authors adjust and shim the door
(left), using 1/8-inch-thick setting blocks to
temporarily set the clearance gap (above
right). |
| Figure
6. With the door gapped and shimmed, the authors
trace the hinge location onto the threshold (above,
left). It's difficult to completely seal a frameless
enclosure, especially if the client doesn't like the
look of the polycarbonate seals and edge wipes. The
authors emphasize that wood floors and frameless
enclosures make poor bathmates. Delicately handling
heavy glass panels is always a two-person job (above,
right). With the side panels permanently set and
caulked, the pivot hinges can be secured and
final-adjusted. Clearance around the hinge body allows
minor adjustments to be made in the door's position
(left). |
The hinges, which clamp onto a cutout in the door, permit
minor side-to-side adjustments before the set screws are
tightened. We prefer to keep the gap around the door as narrow
as possible, to reduce water escape, but it is always wise to
hedge against the building settling, especially in new
construction. Working with demanding precision in tight
quarters with heavy glass, and continually disassembling and
reassembling the components is a little nerve-wracking, but
fortunately we're married, so we're used to each other. For the
most part, we've gotten our system down to a familiar routine,
and the two of us can complete an average frameless
installation in one long, 8-hour day.
Before we go, we always leave a gift of a shower squeegee
and a bottle of surface protector, along with instructions on
how to keep the enclosure looking as beautiful as it does when
we're done.
Paul and Kathy McLellan
own and
operate Mayflower Glass in Brewster, Mass.
