Maine Passive House, Part 1: Framing Meets Air-Sealing~
Work continued in July and August on builder Chris
Corson’s passive house in Knox, Maine, under construction for
Belfast couple Matt and Heather Diko. Adverse weather, a detour to
finish up an unrelated basement remodel, and the crew’s
unfamiliarity with the house’s advanced framing details
slowed progress in the early going. But by last week, Corson and
his
EcoCor Design/Build crew
were framing the roof. Said Corson, “The idea is to build
this house using methods that any typical builder in America would
be able to learn, and that a typical home-buyer could
afford.”
Above, Corson and his crew set a header for a large window on
the home’s west wall. The load-bearing inner frame’s
window openings are packed out with engineered rim-joist material
to allow the European-made high-performance windows to be set at
mid-wall (see drawing below). But this departure from standard
framing required the crew to slow down and think twice about rough
opening dimensions. “We couldn’t just follow our old
habits,” said Corson — one window opening had to be
re-framed after a layout mistake.
Here’s a closer look at the wall framing and air-sealing
in progress. The building’s airtight envelope concept is
based on attaching and air-sealing an OSB skin over the inner,
load-bearing 2x4 wall frame, before the outer insulated shell of
foot-deep vertical wood I-joists is attached. This inner airtight
layer is simply typical OSB sheathing — except for the tape
seals applied at all joints and penetrations, and the fact that the
OSB layer is buried deep inside the 16-inch-thick wall assembly.
The outer sheathing for the I-joist second skin, when that layer
finally goes on, will be a more vapor-permeable fiberboard
product.
Corson calls this assembly, passed to him by Passive House
Institute US director Katrin Klingenberg, a “hybrid
wall.” He argues that the system achieves the advantages of a
full double-stud-wall frame, but with simpler construction and
air-sealing detailing — and, arguably, with better thermal
breaks.
Air-sealing the OSB layer for the inner wall assembly on site is
simple enough: The plan is just to apply flexible,
tenacious 3M All Weather Flashing sealing tape
over all OSB
joints, and also over nail penetrations where the sheathing is
nailed to intermediate studs between joints (as shown in the next
story below). Corson demonstrated the 3M tape’s flexibility
for Coastal Connection on site, stretching a short piece by hand by
a full inch or more. This, he said, gives him confidence that the
material will readily accommodate the moisture-related movement of
the wood frame in service through many seasons, maintaining the
long-term performance of the air barrier.
As for the tape seal over the nailed sheathing connections in
the field, where the OSB is attached to intermediate studs between
joists, Corson admits that the tape won’t make much
difference when the house is new (nail holes in OSB don’t
leak much air anyway). But if those joints and the nails move and
loosen over time, he says, the tape will serve as a backstop in
future years. “You could actually kick the sheathing right of
the stud at those places, and the tape would still keep it
air-tight,” he says. “It gives me confidence in the
long-term durability of the air barrier.”
