14.4-Volt Cordless Drill-Drivers,
continued
Bosch Brute Tough 33614
Battery: NiCad; 14.4 volts, 2.0 amp-hours, 28.8
watt-hours
Maximum torque: 475 inch-pounds
Weight: 5.3 pounds
Power-to-weight ratio: 90 inch-pounds/lb.
Speed range: 0-450, 0-1,400
Street price: $189
Comments: Excellent power and power-to-weight ratio;
all metal gears; steel reinforcing collar at front of gun.
Bosch Compact Tough 32614
watt-hours
Maximum torque: 300 inch-pounds
Weight: 4.2 pounds
Power-to-weight ratio: 71 inch-pounds/lb.
Speed range: 0-400, 0-1,200
Street price: $159
Comments: Very light and compact; good power for size;
a top choice for finish work.
DeWalt DW983
Battery: NiCad; 14.4 volts, 1.7 amp-hours, 24.5
watt-hours
Maximum torque: 400 inch-pounds
Weight: 5.3 pounds
Power-to-weight ratio: 75 inch-pounds/lb.
Speed range: 0-450, 0-1,400, 0-1,800
Street price: $199
Comments: A solid performer; only drill with three
speed ranges; all-metal gears and gear case; battery has the
lowest amp-hour rating of the tools tested.
Hilti SF150-A
Battery: NiMH; 15.6 volts, 3.0 amp-hours, 46.8
watt-hours
Weight: 4.9 pounds
Power-to-weight ratio: 61 inch-pounds/lb.
Speed range: 0-450, 0-1,450
Street price: $349
Comments: A sleek tool with superior batteries and
run-time; comes with multiposition auxiliary handle.
Hitachi DS14DVB
watt-hours
Maximum torque: 280 inch-pounds
Weight: 4.6 pounds
Speed range: 0-350, 0-1,200
Street price: $149
Comments: Lightweight and low cost but doesn't stand
out in performance.
Makita 6337DWDE Mforce
Battery: NiMH; 14.4 volts, 2.6 amp-hours, 37.4
watt-hours
Maximum torque: 350 inch-pounds
Weight: 4.8 pounds
Power-to-weight ratio: 73 inch-pounds/lb.
Speed range: 0-400, 0-1,300
Street price: $199
Comments: Midsize drill with better than average
run-time; all-metal gears; drill mode activated by shift lever;
unique two-piece motor; a good all-around performer.
Metabo BST 15.6 Plus
Battery: NiCad; 15.6 volts, 2.4 amp-hours, 37.4
watt-hours
Maximum torque: 484 inch-pounds
Weight: 5.1 pounds
Power-to-weight ratio: 95 inch-pounds/lb.
Speed range: 0-450, 0-1,600
Street price: $299
Comments: Highest power and power-to-weight ratio;
unique pulse drilling mode makes it easier to drive and remove
fasteners.
Milwaukee Lok-Tor 0616-24
Battery: NiCad; 14.4-volts, 2.4 amp-hours, 34.6
watt-hours
Maximum torque: 460 inch-pounds
Weight: 5.8 pounds
Power-to-weight ratio: 79 inch-pounds/lb.
Speed Range: 0-500, 0-1,700
Street Price: $199
Comments: Heavy and powerful; all-metal gears and
chuck; comes with multiposition auxiliary handle; battery can
be installed frontwards and backwards, allowing better
clearance for some operations.
Panasonic EY6432GQKW
Battery: NiMH; 15.6 volts, 3.5 amp-hours, 54.6
watt-hours
Maximum torque: 390 inch-pounds
Weight: 4.8 pounds
Power-to-weight ratio: 81 inch-pounds/lb.
Street price: $209
Comments: Most advanced batteries and best run-time;
extremely compact; good power for weight.
Porter-Cable Grip-to-Fit
9978
watt-hours
Maximum torque: 420 inch-pounds
Weight: 5.6 pounds
Street Price: $189
Comments: A big heavy drill; all-metal chuck and gear
case; unique adjustable grip.
