Download PDF version (1848.9k) Log In or Register to view the full article as a PDF document.
Launch Slideshow
Rebuilding on the Gulf Coast
  • http://www.jlconline.com/Images/377007851_1010_JLC_Rebuild%20on%20Gulf_00a_tcm96-1160581.jpg
    600
  • http://www.jlconline.com/Images/1440281388_1010_JLC_Rebuild%20on%20Gulf_00b_tcm96-1160593.jpg
    600
    The Trinity Episcopal Church in Pass Christian, Miss., once stood on piers about 4 feet above grade and 14 feet above sea level. In August 2005, Hurricane Katrina's 26-foot storm surge washed away the walls but left the church's laminated-arch frame virtually intact. During reconstruction the church was raised another 10 feet to assure it would withstand future storms.
  • http://www.jlconline.com/Images/430946357_1010_JLC_Rebuild%20on%20Gulf_01a_tcm96-1160604.jpg
    600
    The shoring crew first disconnected the floor framing from the foundation by cutting the steel bolts embedded in the short concrete piers.
  • http://www.jlconline.com/Images/72651646_1010_JLC_Rebuild%20on%20Gulf_01b_tcm96-1160613.jpg
    600
    The crew installed cribbing and hydraulic jacks for lifting the building.
  • http://www.jlconline.com/Images/297613109_1010_JLC_Rebuild%20on%20Gulf_01c_tcm96-1160621.jpg
    600
    Each jack was connected to a hydraulic manifold powered by a diesel engine.
  • http://www.jlconline.com/Images/1129002363_1010_JLC_Rebuild%20on%20Gulf_01d_tcm96-1160629.jpg
    600
    The jacks were able to lift the 3,000-square-foot structure more than 10 feet with less than 3/8-inch difference in elevation between any of the 10 lifting points.
  • http://www.jlconline.com/Images/1960391617_1010_JLC_Rebuild%20on%20Gulf_02a_tcm96-1160637.jpg
    600
    The rebar for new grade beams and pier extensions was epoxied to the original piers.
  • http://www.jlconline.com/Images/1182940869_1010_JLC_Rebuild%20on%20Gulf_02b_tcm96-1160645.jpg
    600
    Formwork for the pier extensions stopped a foot shy of the raised building to allow for setting the anchor bolt-studded cap plates and pumping the concrete.
  • http://www.jlconline.com/Images/1782445840_1010_JLC_Rebuild%20on%20Gulf_02c_tcm96-1160653.jpg
    600
    Diagonal steel rods provide lateral bracing for the exposed portions of the piers; note the cold joint at the base of each pier between the old pier and the pier extensions.
  • http://www.jlconline.com/Images/1124482700_1010_JLC_Rebuild%20on%20Gulf_02d_tcm96-1160661.jpg
    600
    Steel brackets welded to the cap plates anchor the transept framing to the foundation.
  • http://www.jlconline.com/Images/1962962887_1010_JLC_Rebuild%20on%20Gulf_03a_tcm96-1160669.jpg
    600
  • http://www.jlconline.com/Images/534471819_1010_JLC_Rebuild%20on%20Gulf_03b_tcm96-1160677.jpg
    600
    Cantilevered steel plates (left) welded to the cap plates and existing steel framing brackets in the original floor system provide support for the glulam rim joists (right) that support the new SIP walls.
  • http://www.jlconline.com/Images/1904504718_1010_JLC_Rebuild%20on%20Gulf_03c_tcm96-1160685.jpg
    600
    With the glulam rims secured to the original structure and the new transept floor framing completed, the building is ready for wall A and roof panels.
  • http://www.jlconline.com/Images/813203675_1010_JLC_Rebuild%20on%20Gulf_04a_tcm96-1160691.jpg
    600
    The floor was 14 feet above grade, so man lifts were essential for safe handling of the large panels.
  • http://www.jlconline.com/Images/1105949284_1010_JLC_Rebuild%20on%20Gulf_04b_tcm96-1160701.jpg
    600
    The wall panels are lifted into place with man lifts.
  • http://www.jlconline.com/Images/560382819_1010_JLC_Rebuild%20on%20Gulf_04c_tcm96-1160709.jpg
    600
    Panel edges were relieved at the bottom to fit over the glulam rim joist, and at the sides and top for the 2-by connecting splines.
  • http://www.jlconline.com/Images/583890662_1010_JLC_Rebuild%20on%20Gulf_04d_tcm96-1160717.jpg
    600
    The wall panels were first glued and nailed to the glulam band and splines, then fastened to each other and to existing framing with structural screws.
  • http://www.jlconline.com/Images/106276456_1010_JLC_Rebuild%20on%20Gulf_05a_tcm96-1160725.jpg
    600
    The stiffeners were bolted to the glulam and recessed into the wall panels.
  • http://www.jlconline.com/Images/1087583981_1010_JLC_Rebuild%20on%20Gulf_05b_tcm96-1160733.jpg
    600
    To prevent wind deflection, the tall window walls were reinforced with full-length flitch beam stiffeners.
  • http://www.jlconline.com/Images/1829916290_1010_JLC_Rebuild%20on%20Gulf_06a_tcm96-1160741.jpg
    600
    Preinstalled 2-by walk boards reinforced the connection between the lifting hooks and the OSB skins of the roof panels.
  • http://www.jlconline.com/Images/2047786820_1010_JLC_Rebuild%20on%20Gulf_06b_tcm96-1160749.jpg
    600
    View of roof panel emplacement.
  • http://www.jlconline.com/Images/949562957_1010_JLC_Rebuild%20on%20Gulf_06c_tcm96-1160757.jpg
    600
    Placing the hooks slightly off-center eliminated camber in the panel, making it easier to slide the edge over the spline of the previous panel.
  • http://www.jlconline.com/Images/898195721_1010_JLC_Rebuild%20on%20Gulf_07a_tcm96-1160765.jpg
    600
    The second-story floor system in the transept addition hangs between the top of the first-floor wall panels.
  • http://www.jlconline.com/Images/1647618963_1010_JLC_Rebuild%20on%20Gulf_07b_tcm96-1160773.jpg
    600
    The second-floor structure of the transcept addition is supported by 6x16 glulam beams that span the openings of the arches of the original church frame.
  • http://www.jlconline.com/Images/1132483161_1010_JLC_Rebuild%20on%20Gulf_07c_tcm96-1160781.jpg
    600
    The 32-foot-long structural ridge beam fit into reinforced pockets in the gable SIPs.
  • http://www.jlconline.com/Images/617347359_1010_JLC_Rebuild%20on%20Gulf_08a_tcm96-1160789.jpg
    600
    The nonstructural skirt wall and lowered entry deck make the church appear lower to the ground than it actually is.
  • http://www.jlconline.com/Images/1008475890_1010_JLC_Rebuild%20on%20Gulf_08b_tcm96-1160797.jpg
    600
    There's elevator access from the finished slab underneath the building.
  • http://www.jlconline.com/Images/650349292_1010_JLC_Rebuild%20on%20Gulf_08c_tcm96-1160805.jpg
    600
    With the arches and finish ceiling intact — and the original stained-glass window back in place — the interior looks almost unchanged.
Finishing Up
Since the bottoms of the SIPs were 14 feet above grade, we wanted to disguise the overall height of the church with a conventionally framed “skirt.” To satisfy FEMA requirements, this skirt had to be nonstructural and somewhat less substantial than the SIPs so that it would break away in the event of flooding. Therefore, we framed 30-inch-tall wall sections with 2x6s underneath the glulams. Where the deck, stairs, and hvac platforms would be attached, we bolted PT 2x12 ledgers to the piers at the same elevation, helping to create the illusion that the church is only 10 feet above grade (see slideshow).
Cost. The SIPs package cost $128,000, including all of the associated fasteners and hardware and two weeks of site time by the factory’s trainer — a small percentage of the project’s $1.9 million total budget. And even though we’d never worked with SIPs before, it took less than four weeks for my five-man crew to assemble the panels. I doubt we could have stick-framed and insulated a building this size with the same energy efficiency and hurricane resistance for anywhere near that price.
As we moved on to the housewrap and trim and reinstalled the stained-glass gable-end window — salvaged from 4 inches of mud in the church parking lot — the old building’s familiar profile began to reemerge. But this church will be much better equipped than its predecessors to weather the next storm that hits Pass Christian.
Matt McBride owns More Than a Carpenter, a general contracting business in Pass Christian, Miss.
