Before getting a license to practice medicine, a new doctor
has to swear to uphold the Hippocratic oath to "do no harm" to
any patient. If there were a similar oath for remodelers (the
Palladian oath?), builders would have to swear not to leave a
remodeled house looking uglier than it was before. That's not
difficult if you're starting with a charming old farmhouse or
some other character-rich design, but when you're remodeling a
house that didn't have any style to begin with, it can be a
real challenge.
That challenge is a common one nowadays, when the number of
style-deficient post-WW II houses in need of major remodeling
is at an all-time high. My architectural practice here in
Minnesota is dominated by remodeled designs of such newer house
types as split levels, ranches, and the ever popular "raised
ranch" shown here.
The front facade of this 60s-vintage
raised ranch is dominated by the huge tuck-under garage door,
making the actual main entrance look like an afterthought. The
fenestration or window pattern is a jumbled mess with no
balance, rhythm, or character. The only design quality to build
on is a strong emphasis on horizontal lines.
Thoughtful use of color is a quick and
inexpensive way to add character. Here we've painted the siding
a barn red and specified a quiet, light-gray shingle that
connects back to the exposed concrete-block base. The barn red
makes the house stand out in the neighborhood of beige houses,
but more important it makes the white trim pop out, emphasizing
what little detail the house has. Residing the house with a
thinner horizontal siding adds visual texture and strengthens
its existing horizontal lines, as does the addition of
horizontal 2x2 battens to the existing garage
door.
The biggest functional problem with the
existing house was a front entry that dumped visitors onto a
tiny stair landing. A new front entry provides much-needed
transition space and adds a strong vertical element that
emphasizes the horizontal through contrast.
Just as important as changes to the
house itself are design moves to extend the house into the
landscape. A new front walk extends toward the street, and a
low fence draws your eye to the front door. A row of bushes
along the new walk also draws attention to the front door,
deemphasizing the garage door. Peeking around the side is a new
deck and screen porch, each with strongly horizontal
detailing.
Many of these designs evolved during the sixties and
seventies, when builders could sell pretty much anything.
Houses were stripped of ornamentation, with no attention paid
to such design basics as contrast, proportion, scale, balance,
and rhythm. Despite their stylistic shortcomings, many of these
houses are built on lots with mature trees in desirable
neighborhoods. Such amenities can't be replicated in today's
greenfield developments, so there's strong demand for these
homes and lots of incentive to update their appearance.
Here are a few basic design ideas that I've found useful for
injecting some style into houses that desperately need
it:
* Build on what you've already got. In a typical raised ranch,
the only identifiable design motif is an emphasis on
horizontality. Take advantage of it by working with design
elements that reinforce that focus.
* Use color to create character. Most speculative houses are
beige and bland. Infuse a dose of color by repainting and
reroofing.
* Extend the house into the landscape. Create outdoor rooms
and spaces with lots of detail to compensate for the lack of
detail in the original house.
* Finally, don't load a house with more style than it can
support. You can't turn a humble raised ranch into Tara from
Gone With the Wind, and you shouldn't try. Don't forget
your remodeler's oath.
Robert Gerloffis a residential architect in
Minneapolis, Minn.
