In a down market, businesses have to find a way to set
themselves above the competition. Technical proficiency is one way
to do that; and in the coastal market of Florida’s
“Space Coast,” near Cape Canaveral,
New Smyrna Beach Construction
Company
New Smyrna Beach Construction Company is finding
success with that strategy.
Ten years ago, company V.P. George Barrett told Coastal
Connection NSB was building with wood, just like its competition.
But as wind-related codes got tougher, the company took on the
challenge not just to meet the code, but to go beyond it. Today,
Barrett says, “I tell customers that the code is just a
minimum. I’ll build to the minimum if that’s all the
budget allows; but I offer them the chance to build something much
stronger.” Even concrete block doesn’t satisfy Barrett:
when you see windborne debris testing of a block wall, he says,
“the 2x4 blasts right through the blocks where the cores are
hollow. With a concrete wall, the projectile shatters, and you
can’t even tell where it hit the wall.”
Barrett took Coastal Connection on a walk-through of a current
beachfront project on South Atlantic Avenue in New Smyrna Beach
— a teardown of an old wooden A-frame house, and the
construction of a new poured concrete house. The 8-inch-thick
reinforced concrete walls were built with a conventional forming
system, while the floors were formed with a post-tensioned ICF
system. Only the roof framing is wood; the low-slope trusses have
2x6 top and bottom chords, and the roof is insulated with Icynene
spray foam.
Rising like a concrete castle from the dunes,
dunes, the house has a rock-solid feel (top); the upper-floor
window’s will offer a royal view of the open Atlantic and the
white sand beach (second from top), while the garage floor level,
built into the dune, offers bomb-shelter-like security against high
winds. Intermediate floor systems are foam-insulated ICF
construction, with post-tensioning cables sufficient for a 36-foot
clear span (second from bottom). The roof insulation is airtight,
low-density spray foam (bottom).
The airtight roof insulation and the thermal mass of the
concrete give the house a head start on energy efficiency: even
under construction and with no air conditioning, the house felt
cool on an 80-degree day in March. And the the home’s
spectacular beach views will come with a relatively tolerable risk
for the owners: despite its 120-mph design wind speed, Exposure B
location, the house will be far more secure in case of hurricane
than its wood-framed neighbors on the beach.
