As a structural engineer with the APA/Engineered Wood Association, I perform forensic assessments of single- family homes after hurricanes and tornados. On April 16, severe tornados damaged and destroyed many homes in the eastern part of my home state of North Carolina. While I was there on assignment, documenting the destruction around Fayetteville, Raleigh, and Wilson, news came of a much more destructive batch of tornados passing through Mississippi, Alabama, Georgia, and Tennessee. Back on the road the following week, I visited areas of Alabama that had been damaged by the most severe wind forces I have ever documented - places where buildings, trees, signs, and other familiar landmarks were simply gone, causing residents to become disoriented in their own neighborhoods.
After visiting storm-damaged areas, empathy for those who have lost their homes often leaves me with a sort of post-traumatic stress that lasts for a few weeks as I return to normal life. This time I had a different reaction, however, as I realized that recent APA test results on foundation anchors could be used to protect homes from future storms. The study, which looked at walls sheathed with plywood and OSB, filled some gaps in our understanding of the critical connection between exterior walls and the foundation. It showed that closely spaced anchors used in conjunction with 3-inch-by-3-inch plate washers dramatically increases the capacity of walls to resist simultaneous shear (racking) and uplift forces. In the recent tornado outbreaks, exterior wall anchorage often made the difference between a structure that provided some level of protection to occupants and one that was swept clean from the foundation. In many cases, the roofs and walls themselves were strongly built, but poor wall-to-foundation anchorage resulted in sudden and catastrophic failure.
In tracking the tornados in eastern North Carolina and Alabama, I focused on the performance of homes built within the last 10 years. In many cases I could see weak links in the load paths that contributed to structural failure. Unfortunately, there's a common misconception that all tornados are too violent to resist, no matter how strong the framing. In fact, 95 percent of tornados are rated EF0, EF1, or EF2 by the National Weather Service; these weaker tornados produce winds that a well-built home can be expected to withstand.
View Illustrations, pp. 2-3
DownloadIn the Path of the Sto...
(4124kb)
Improving Tornado and Hurrican Resistance of Wood-Frame Buildings; Tornado Paths, Enhanced Fujita Scale, Damage Assessment Tools
In response to the recent storms, APA has developed construction recommendations designed to strengthen the overall structural shell so that it can better withstand the forces of tornados and hurricanes. The recently published document "Building for High Wind Resistance in Light-Frame Wood Construction" (available for download at apawood.org/tornados) provides prescriptive details that rely on standard framing and sheathing materials, with a minimum of additional hardware. The intent is to show builders how to optimize the structural performance of their homes without great expense, to help prevent the kind of damage described on the following pages.
While stronger tornados (EF3 to EF5) are harder for a home to survive, these details may still help, especially for buildings located along the periphery of the tornado's path - away from the vortex - where wind speeds are lower.
Bryan Readling is a structural engineer with APA's Field Services Division in Davidson, N.C.
Fayetteville, N.C.
Damage to this home most likely started with the failure of the garage doors. Subsequent pressurization of the garage blew out the sidewall and pushed out the back wall. A close look showed inadequate nailing of the drywall ceiling and the bonus-room floor sheathing to the bottom chord of the gable-end truss, seen here from behind. The gable triangle was intact, with the OSB sheathing still in place - it's the connections that failed.
The same home, seen from the rear, also lost sheathing at the step-down trusses of the hip roof, a type of failure I observed several times. Top-chord nailing surfaces on step-down trusses do not neatly align with the roof sheathing, which makes it more difficult to attach the sheathing adequately.
A nearby home also lost gable-end attic trusses in two places. The garage doors (barely visible at the left end of the house) were breached, allowing the gable wall and roof to be blown off.
Another home in the same subdivision fared much worse; most likely the garage walls were blown out due to pressurization through the large garage-door opening, seen in the foreground. A closer look at the left-hand garage wall shows that the OSB sheathing was poorly attached to the bottom plate with 8-penny nails 16 inches on-center. Foundation anchor bolts with round washers were spaced 48 inches on-center along the sill plate. The home's roof trusses had been attached with toenails.
The rafters on another house in the neighborhood were attached with metal connectors; note, however, that the metal ties were nailed to the inside of the top plate. They should have been installed on the outside of the wall, in alignment with the load path through the plywood sheathing.
Another collapsed home was fully sheathed with OSB, which lapped the rim board and sill plate but was fastened only to the rim board with 16-penny nails at approximately 16 inches on-center. I could see no nails through the sheathing into the sill plate.
These two homes lost much of their fiber-cement siding, but there were no breaches in the OSB sheathing.
