15-Gauge Angled Finish Nailers - Continued
Bostitch N62FNK-2
Street price: $199
Weight: 3.8 pounds
Firing modes: sequential, bump
Nail type: Bostitch/FN
Nail capacity: 130
Magazine type: load-and-lock
Made in: USA
The N62FN has an excellent power-to-weight ratio. It sets
fasteners as consistently as any tool I tested and is
significantly lighter than most guns. It takes FN rather than
the more common DA-style fasteners and is one of only two
nailers that doesn’t take oil. This tool is sleeker and
less cluttered than others because there’s no latch on
the front. Instead, jams are cleared by releasing a catch and
popping the magazine back from the nose. The only thing I
don’t like about this tool is that it’s configured
for sequential trip. Some carpenters don’t consider this
to be a shortcoming, but if you do, you can convert it to
bump-fire by changing the trigger.
Contact: Stanley Fastening
Systems, 800/228-0567, http://www.stanleyworks.com.
Campbell Hausfeld NB356599
Street price: $160
Weight: 5.4 pounds
Nail type: DA
Nail capacity: 100
Magazine type: lock-and-load
Made in: Taiwan
The only thing that’s special about this nailer is the
price. It’s not a bad tool, but for a little more money
you can buy a far superior gun. The NB356599 is relatively
heavy and has a tough time setting fasteners in hard, thick
wood. Interestingly, it shares parts with some of the other
guns I tested. The magazine, which is the best part of the
tool, is identical to the one on Max’s NF550. I know,
because I swapped them out. And the cylinder cap assembly is
interchangeable with the one on Duo-Fast’s
DAFN6480.
Contact: Campbell Hausfeld,
888/247-6937, http://www.campbellhausfeld.com.
DeWalt D51275K
Street price: $249
Weight: 3.85 pounds
Nail type: DA
Nail capacity: 110
Magazine type: lock-and-load or load-and-lock
Made in: Taiwan
DeWalt hasn’t been in the nailer business for very long,
so I was surprised by how much I liked its first 15-gauge
nailer. The D51275 has power to spare and is less than an ounce
heavier than the lightest tool in its class. Features like the
built-in belt hook and bumper pads on the piston housing are a
sign that the design team paid attention to the details. The
depth-of-drive is indexed to a scale, and you get a good view
of the work because the contact element is thinly clad. My only
complaint is that the exhaust blast torques the gun sideways
when the port is set 90 degrees to the handle. But the problem
is easily fixed by aiming the port slightly to the front or
back.
Contact: DeWalt Industrial
Tools, 800/433-9258, http://www.dewalt.com.
Duo-Fast DAFN6480
Street price: $250
Weight: 5.4 pounds
Firing mode: sequential
Nail type: DA
Nail capacity: 100
Made in: Taiwan
This finish nailer has been around for six-plus years. It has
stayed the same while nearly every other gun has improved. It
closely resembles and shares a number of common parts with
Campbell Hausfeld’s NB356599. The DAFN6480 is one of the
heavier 15-gauge guns and had more trouble setting fasteners
than any tool I tested. There’s no reason to buy this gun
with so many better ones available in the same price
range.
Contact: Duo-Fast,
888/386-3278, http://www.duo-fast.com.
Hitachi NT65MA
Street price: $339
Weight: 4.2 pounds
Firing mode: bump
Nail type: DA
Nail capacity: 100
Made in: Japan
This is a new version of an earlier Hitachi finish nailer. It
was the lightest 15-gauge tool on the market but was recently
undercut by other models. That said, the NT65MA is still one of
the lightest nailers around. It has plenty of power and
features, like an in-line magazine, a well-padded grip, and
no-tools jam clearing. Unlike that of most guns, the
depth-of-drive is indexed to a scale. The most unusual thing
about this tool is the blow gun, which consists of a small
nozzle and trigger button built into the piston housing. It may
be a bit of a gimmick, but I love this feature because it means
I can blast dust and debris out of the way without having to
connect a separate blow gun.
Contact: Hitachi Power
Tools, 800/830-7593,
http://www.hitachi.com/powertools.
Makita AF632
Street price: $249
Weight: 5.5 pounds
Firing mode: bump
Nail capacity: 125
Made in: Taiwan
This is one of two guns that take FN-style nails. It replaces
the earlier model AF631, a gun that compared favorably with the
competing Bostitch model. Unfortunately, the AF632 does not
— it’s heavier and more expensive. This nailer is
moderately powerful and appears to be well made. It has an
offset magazine, a padded rubber grip, and a large indexed
depth-of-drive wheel.
Contact: Makita USA,
800/462-5482, http://www.makitatools.com.
Max NF550
Street price: $275
Weight: 4.6 pounds
Firing mode: anti-double-fire, bump
Nail type: DA
Nail capacity: 100
Made in: Japan
The NF550 is sleek, powerful, and well made. Someone sweated
the details when they designed this gun. It has a
user-activated trigger lock and a large indexed depth-of-drive
control. There’s even a place to store the tip if you
need to take it off. The NF550 will bump-fire, but it also has
a unique anti-double-fire mode. In this mode, you depress the
contact element before you squeeze the trigger. This prevents
double shots because the gun won’t cycle till you release
the trigger. I prefer in-line nailers, but if you want an
offset magazine, this is the gun to get.
Contact: Max USA,
800/223-4293, http://www.maxusacorp.com.
Porter-Cable DA250A
Street price: $199
Weight: 6.0 pounds
Nail type: DA
Nail capacity: 100
Made in: Taiwan
When the DA250A came out, it was significantly cheaper than
other brand-name tools with similar features. But that was
five-plus years ago, and the price gap is much narrower now.
This tool has all the usual features — a rubber grip,
indexed depth-of-drive, tool-less jam clearing, and an
adjustable exhaust port. The contoured contact element and thin
rubber tip make it easy to see where you’re nailing. This
tool has excellent power but is the heaviest gun I
tested.
Contact: Porter-Cable,
800/321-9443, http://www.porter-cable.com.
Senco SFN40
Street price: $249
Weight: 4.7 pounds
Firing mode: bump
Nail type: DA
Nail capacity: 110
Made in: USA
When the SFN40 came out, it was the only oil-less gun on the
market and stood head and shoulders above the competition.
Though it hasn’t changed in six years, it’s still
one of the better finish nailers around, an extremely durable
and powerful tool. The one thing I don’t like about it is
the exhaust port, which is adjusted by removing and replacing
snap-in pieces. Everyone else switched to rotating ports years
ago. By the time you read this, Senco will have introduced
three new 15-gauge angle nailers: two pneumatic and one powered
by batteries alone. They weren’t available in time for me
to review them.
Contact: Senco Products,
800/543-4596, http://www.senco.com.
David Franeis a finish carpenter and contributing editor for The
Journal of Light Construction.
