Publication Date: March/April 2003
Combination HammersTool | Weight | Amps | RPM | Blows Per Minute | Maximum Impact Energy | Cord Length | Street Price |
Bosch
11241EVS | 14 lbs. | 11 | 220 to 400 (loaded) | 1,700 to 3,300 (loaded) | 7.4 foot/pounds | 8 feet | $549 |
Comments: This is a
terrific, well-engineered machine for someone who does
more horizontal work than I do. It's got great power
for a mid-weight tool. It's well balanced, and
vibration isolators prevent excessive vibration and
operator fatigue, which is vital. I like the power
indicator and speed selector switches. It has a good
box. 877-267-2499. www.boschtools.com |
DeWalt
D25600K | 13.4 lbs. | 11 | 140 to 280 | 1,330 to 2,660 | 8 foot/pounds | 13-1/2 feet | $699 |
Comments: While lightweight,
this tool has impressive power. I like the feel and
balance, which is good for horizontal work. The tool
exhausts cooling air over a wide area, so it kicks up
less dust than the others. I like its dual-mount
handle, but when in the upper position by the trigger,
it blocks the mode selector switch. The box seems tough
enough, but the partitions inside could be a little
sturdier. *I tested a prototype model. The tool ships
this month. 800-433-9258.
www.dewalt.com |
Hilti
TE 76-ATC | 17.4 lbs. | 11 | 0 to 282 | 0 to 2,770 | 6.1 foot/pounds | 10 feet | $1,699 |
Comments: This is
the most powerful tool in the group, plus it's the
smoothest to operate. It's balanced enough for
horizontal work, although a bit heavy. I like the
switches, especially the 50 percent and 100 percent
power selection, which increases both the BPM and RPM.
The trigger lock for chipping gives your hand a break
from squeezing the trigger. The electronic torque
control (ATC) is nice. It needs a box that clearly
indicates the top and bottom. 800-879-8000.
www.us.hilti.com |
Hitachi
DH40MB | 14.2 lbs. | 8.7 | 180 to 360 | 1,400 to 2,800 | 5.9 foot/pounds | 8 feet | $460 to $500 |
Comments: This is a solid tool
with very good power. It's well-balanced and
ergonomically advanced. I'm not crazy about the switch
design and location (underneath the tool body). It's
got the largest box of the bunch, which can carry
plenty of bits and accessories. 800-829-4752.
www.hitachi.com/hpt |
Makita
HR4000C | 13.6 lbs. | 9.6 | 230 to 450 | 1,250 to 2,500 | 4.94 foot/pounds | 16-1/2 feet | $565 |
Comments: I like
this hammer a lot. It's well designed, nicely balanced,
and lighter than most of the tools we tested, so it
doesn't quite pack the punch of the others. However,
its compact design and variable handle option make it
extremely versatile, especially for horizontal work
like masonry demo or breakthrough in concrete. The
D-handle is a nice addition for horizontal and overhead
chipping. It's got a good switch and well-designed box.
800-462-5482. www.makita.com |
Metabo
BHE6045S | 18.3 lbs. | 10.6 | 105 to 275 | 1,000 to 2,600 | 6.049 foot/pounds | 13 feet, 6 inches | $839 |
Comments: Metabo's is the
largest tool of the lot and has enough power to handle
any application. It's a bit heavy for horizontal work
but will get the job done well. It's got a nice,
comfortable, and large side handle you can use in two
locations -- near the chuck and at the trigger grip. I
think the function switch needs better graphics to
indicate what function the tool is on. 800-638-2264.
www.metabousa.com |
Milwaukee
5315-21 | 13.9 lbs. | 11 | 190 to 385 | 1,700 to 3,400 | 7.9 foot/pounds | 10 feet | $499 to $529 |
Comments: Milwaukee
has a well-made, compact tool with nice features. The
vibration isolators really reduce fatigue without
compromising tool control and feel. There's a good
switch with clear, concise graphics. The Quik-Lok cord
is a nice feature that allows for easy storage in the
box and damaged cord replacement. I'm not impressed
with the traditional metal box, though, it adds weight
and dents easily, affecting proper closure.
800-729-3878. www.heavydutytool.com |
This article is reprinted
courtesy of
Tools of the Trade
