Braced for Savings
The Truss Spacer Bracer attaches with nails and is designed to be left in place under the sheathing.
By Lee McGinley. The romance of hand-cutting rafters for an addition’s roof quickly evaporates when you’re boosting 2x12s into place. It’s up and over the double plate, then hand-over-hand up staging and ladder to the ridge, while someone else makes sure the bird’s mouth fits just so.
There’s no question that manufactured roof trusses make roof framing easier. However, spacing them 24 inches on center and holding them in place until you nail on the sheathing requires temporary wood bracing, which is then removed prior to sheathing. That all takes extra time and materials. (Not to mention time and labor lost should you have an inaccurate layout.)
The options
Here are three “space-and-brace” metal products that could save you on that time and materials. The first two have dual functions: They provide 24-inch spacing while setting trusses and, because of their low profile, you can sheath right over them. You’ll still have to nail a strong back to the gable end to plumb and secure the first truss, but setting the remaining trusses should be easier and more accurate.
MiTek’s Stabilizer ( www.mii.com) has side flanges, which bump against the top chords of adjacent trusses to assure proper spacing. You hammer pre-punched teeth on the top flap into the top chord, then bang in teeth on the side flanges. MiTek claims that with its product, hip ends can be pre-assembled on the ground before they’re lifted into place with a crane.
MiTek’s Hinge Plate technology is for remodelers who have wrestled with piggyback trusses, as I have. The Hinge Plate technology eliminates the cap truss and associated rows of 2x bracing between the cap and the bottom truss.
The Truss Spacer Bracer attaches with nails and is designed to be left in place under the sheathing. The cap truss is actually folded into the bottom truss, then unfolded on the jobsite. All the truss installer has to do then is nail off one side of the peak hinge plate. Hinge plates attached to the top chord allow truss sections to fold flat for shipping and handling, while a modified hinge plate at the peak joins opposing top chords.
Simpson’s Truss Spacer Bracer ( www.strongtie.com) installs with nails, rather than prongs, and captures each truss by slipping over the chords. The 1/16-inch “slop” in each end compensates for thicker 2x stock and allows the installer to reduce creep.
Both the MiTek and Simpson products sell for about $1.50 per spacer.
The reusable Accurate Truss Brace opens like a folding rule and holds up to eight trusses in place. The third product is Accurate Truss Brace ( www.accuratetrussbrace.com), which provides only temporary spacing guidelines and is removed as carpenters sheath their way up the roof. Like a folding rule, it opens to set eight trusses. The precise 24-inch spacing of the rivets holds the legs together to guarantee no creep, pinching each truss into place. No tools or nails are required. A Starter Clamp aligns the first brace on the center of the first truss. Because the product is reusable, it’s made of heavier steel than the sheathed over braces. Tom Philipps, the company’s president, claims the payback time (labor saved) on the initial purchase ($40 per brace) is four jobs.
These products won’t eliminate diagonal or cross bracing. You’ll still have to abide by the manufacturer spec sheets for proper bracing. But with any of these products, brace yourself for some labor savings.
Lee McGinley, CR, a Big 50 remodeler, has written for THE JOURNAL OF LIGHT CONSTRUCTION. He lives in Addison, Vt.
Lee McGinley
Lee McGinley designs and builds high-performance houses from his home base in Addison, Vt.
