First Look: Paneling, Decking, Tile, and more
The newest products for the remodeling market.
Teragren.
Stylish and sustainable, the company’s solid bamboo panel qualifies for LEED as a rapidly renewable resource and low-emitting material. The 12×84-inch panel is 13/16-inch thick, and is offered in either flat or vertical grain and six standard colors. Custom colors can be special-ordered. 800.929.6333. www.teragren.com.
Correct-Deck.
CX with Safeguard is touted as the first antimicrobial composite decking. It resists mold and mildew, stains, and color fading, says the maker. The co-extrusion process applies Safeguard antimicrobial agent to each plank. CX is offered in five colors and a variety of widths. 877.3325.877. www.correctdeck.com.
NuTone.
The Video Door Answering System combines a chime with a door monitor, allowing homeowners to see and communicate with whoever is at their door. The system operates either as a standard security station with a wall-mounted monitor, door chime, and camera, or with a drop-down monitor that supports two cameras. 888.336.3948. www.nutone.com.
Oceanside Glasstile.
The latest addition to the Tessera mosaic tile line is Red #777, a glossy, ruby-red gem. The company incorporates postindustrial scrap glass into its proprietary formula to create the dramatic color. The hand-cut glass tiles are offered in four sizes: 1×1, 1×2, and 2×2 inches, and a 1¾-inch hexagon. 760.929.4000. www.glasstile.com.
Milwaukee.
The heavy-duty Right Angle Drill attachment allows contractors to drill holes or drive screws quickly and easily in tight spaces, the maker says. The attachment accepts ¼-inch hex drive accessories and is ideal for cordless 2.4- to 18-volt drills. 800.729.3878. www.milwaukeetool.com.
OSI Sealants.
Part of the Pro-Series line, QUAD low VOC advanced formula sealant is the recommended sealant for James Hardie and CertainTeed fiber cement siding. It’s also the leader in color matching for the siding industry, with more than 150 shades. 800.999.8920. www.osiproseries.com.
1st United Door Technologies.
Six new solid arches are available for window designs on the Steel-house Carriage Door. The all-steel garage door features 28-inch-high sections laminated with EPS foam and a high-impact vinyl back-skin, and incorporates roll-formed, 23-gauge, steel C-channels. The doors can be accessorized with a variety of hardware options. 480.705.6632. www.firstudt.com.
MAAX.
Created with ergonomic design in mind, the Living series of oval tubs can be fitted with a selection of optional massage systems, including the new Aerofeel perimeter air system. Aerofeel’s tiny openings are positioned around the interior wall and backrest to create a gently rippling massage. A water heater and mood light are also available. 800.463.6229. www.maax.com.
