First Look: Products For the Remodeling Market
The newest products for the remodeling market. Lasco Bathware. Available in the Champagne Bubble bathtub series, Air Bubbler technology encircles the bather with warm bubbles from air portals at the bottom of the deep bathing well. Users can select from three settings and multiple speeds. Seven tub styles and more than 20 colors are available. (800) 877-2005. www.lascobathware.com.
Temple-Inland. The TrimCraft Cornice System includes engineered wood trim, soffit, and ceiling panels made with a manufacturing process that ensures moisture resistance. The products come in a variety of widths, with multiple trim options, precut soffit panels, and full-sized ceiling panels. (800) 231-6060. www.temple.com.
Dwyer Kitchens. Designed for small spaces, the Metro Series compact kitchen features textured steel cabinetry, a removable refrigerator/freezer, a Ceran two-burner cooktop, and a stainless steel countertop. The kitchen comes in three widths: 30, 39, and 48 inches. Upper cabinets are available as an option. (800) 822-0092. www.dwyerkitchens.com. Kohler. The Ingenium toilet flushing system offers the same performance at 1.6 gallons per flush as 3.5-gpf models, says the maker, providing a powerful, yet quiet, flush with a sustained swirling motion that rinses the bowl clean. The new system can be found on most of the company’s toilet models. (800) 456-4537. www.kohler.com.
XACT. The 1950 cellular composite replacement window comes with tilt-in sash, double-cam locks, and recessed tilt latches. The window, which is prefinished and paintable, is custom built for full frame or pocket frame installations. (717) 365-3300. www.mihomeproducts.com.
Johns Manville. EasyFit perforated fiberglass insulation features vertical perforations that allow installers to custom fit batts into non-standard wall cavities by separating the batts by hand. The insulation comes in 15-by-93-inch R-13 unfaced batts. Kraft-faced versions also will be available soon. (800) 654-3103. www.jm.com.
