13 Show-Stopping IBS and KBIS Debuts
Headed to Design and Construction Week in January? Don't miss these 13 new products.
6 MIN READ
There’s a different kind of magic happening in Orlando this month as thousands of building and remodeling industry pros from around the world flock to the International Builders’ Show and the Kitchen & Bath Industry Show 2017. Design and Construction Week offers a lot to see and do—in addition to education sessions and networking events, nearly 2,000 manufacturers and suppliers fill the show floors with new products and services. Of that impressive number, we’ve selected 13 stops you don’t want to miss.
Marvin Windows and Doors
The new Marvin Bi-Fold Door brings expansive views to homes with one of the widest panel doors in the industry. The door provides larger maximum frame heights and panel widths for large glass openings, allowing designers to use fewer panels to create even larger, less obstructed views. The doors can be customized with different panel configurations and use less visible hardware than before for a clean, streamlined look. marvin.com. Booth W2529
Kwikset
The new San Clemente handleset from Kwikset is a modern hardware piece featuring clean lines and a low-profile design for a contemporary entryway. The San Clemente features the advanced SmartKey re-key technology, along with a deadbolt that is bump-proof, pick resistant, kick-in resistant, drill resistant, and saw resistant. The handleset features an adjustable screw, allowing for easy door mounting and a guaranteed fit. The product will be available in Venetian Bronze, Satin Nickel, Polished Chrome, Satin Chrome, and Iron Black finishes. kwikset.com. Booth S3416
Spotlights
Spotlights
ODL
ODL extends the offerings of its Spotlights doorglass designs with five new options in a variety of architectural styles to match any home, including clear, clear low-e, cubed, frosted, and circuit glass. The low-e finish provides homeowners with energy savings by increasing insulation and reducing the amount of UV rays that enter the home. odl.com. Booths S1128, S1800
Johnson Hardware
Johnson Hardware’s new 1562 Series Commercial Grade Bypass Pocket Door Frame offers twice as much width as the company’s standard pocket doors for a wider room divider using a single wall recess. The frame is designed to support two heavyweight (up to 200 pounds each), solid-core bypass doors in a standard 2×6 timber-framed or steel-framed stud wall and accommodates doors up to 3 feet wide, 9 feet high, and 13/8 inches thick. johnsonhardware.com. Booth S1333
American Standard
The new ActiClean Toilet from American Standard cleans itself—users press a button and let the system do the rest. The self-cleaning toilet combines the power of VorMax flushing technology with a fully-integrated cleaning system, eliminating the need for manual cleaning or clip-on solutions that can damage toilet bowls. The cleaning control panel is hidden under a flip-up lid on the tank, where users can activate the system and choose from two cleaning cycle options: a one-minute quick clean or a 10-minute deep clean. The VorMax technology fills the bowl with cleaning solution and then siphons the cleaning agent out and rinses the bowl with clean water. americanstandard-us.com. Booth W1547
Armstrong Flooring
Alterna’s engineered stone flooring material provides the look of stone or tile for a stylish, resilient choice in hard-working rooms such as kitchens and bathrooms. The material is about 20 degrees warmer to the touch than ceramic or stone—which makes it more comfortable on homeowners’ feet—and is stain resistant, says the company. The line offers various options including travertine, marble, slate, and urban-inspired designs featuring weathered metal, linen, concrete, and reclaimed wood. armstrongflooring.com. Booth W6953
LG Studio
LG electronics debuts its first flat-panel, counter-depth refrigerator with instaView technology, which features a glass front panel that illuminates with two quick knocks to allow users to look inside the refrigerator without opening the door, saving both time and energy. Additionally, a door-in-door feature allows users to access frequently used items without having to open the entire unit. The ColdSaver panel, a barrier between the interior compartment and the rest of the refrigerator, helps reduce cold air loss. lgstudio.com. Booth W309
51192
51192
Moen
Moen introduces new contemporary product offerings, including the sleek, one-handle lever Genta faucet. The Genta model features curved edges and a unique flat spout with a twisting ribbon flow for a more modern feel. The faucet is available in single- or three-hole mount configurations. The full suite offers faucets, tub and shower valve components, and matching accessories. The faucet has a 1.2 gallon per minute flow rate. All are currently only available in a Chrome finish. moenpro.com. Booth W2155
PlyGem
PlyGem introduces steel cladding to its line of siding products. The Steel Siding Collection is made of galvanized steel and is able to stand up to hail, wind, and snow, and is fire resistant, says the company. The siding is made of 50% recycled material and is 100% recyclable itself. An embossed wood grain textural pattern gives the steel a look similar to wood, and homeowners can choose from a variety of color options. The siding is treated with a silicon modified polyester coating for increased color retention. plygem.com. Booth W2501
Broan
Broan’s new line of under-cabinet range hoods features an advanced three-speed blower/wheel design with a centric inlet to remove smoke and odors faster, the firm says. A Heat Sentry feature detects excessive heat and adjusts the blower speed to provide proper ventilation and prolong the life of the unit. The vents are available in two styles, Glacier and Spire, with a variety of width options and colors. broan-nutone.com. Booth W2553
Royal Building Products
Royal Building Products has expanded its premium decking line with the introduction of Zuri Grooved Boards, which offer a hidden fastener application with pre-threaded screws for fast installation. The grooved boards also provide two options for a finished look with tighter seams between the boards—a 3/32-inch gap or a 3/16-inch gap. The decking boards come in five coordinated color options and have 25-year no-fade protection. zuri.royalbuildingproducts.com. Booth W3840
Haas Door
Haas Door expands its line of steel garage doors with 13 solid color options, plus two wood grained base options. The steel doors have wood overlay boards that give the garage the aesthetic value of a carriage house look without the maintenance of wood. Each door is 2 inches thick and features CFC free polyurethane insulation with an R value of 13.45. They are available as single or double doors with a number of top section and window customizations. haasdoor.com. Booth S1078
Progress Lighting
Progress Lighting introduces three new collections: The Vestique line features an array of glass spheres suspended within a modern frame that reflects and refracts light for a dramatic focal point. The collection includes wall sconce, mini pendant, semi flush, and oversized pendant options. The Cinq line (pictured) utilizes geometric shapes that bounces light from five-sided bottom panels with mirrored glass. Flush mount and pendant options are finished in an Antique Bronze finish. The Elevate line is designed with a mid-century modern aesthetic. The trapezoidal chandelier features glass shades and a frame inspired by Space Age styling in a Brushed Bronze or Chrome finish. A flush mount fixture is also available. progresslighting.com. Booth W4441
Lauren Shanesy
Lauren is a former senior associate editor for Hanley Wood's residential construction group.
