Combi Gas Boiler
Weil-McLain Simplicity high-efficiency combination gas boiler
Weil-McLain’s Simplicity high-efficiency (95% AFUE) combination gas boiler is designed to provide both hydronic space heating and domestic hot water (though it can also be installed as a heat-only unit). The boiler has an insulated stainless-steel firetube heat exchanger with a vertical “self-rinsing” orientation for easier maintenance, and the touchscreen display reportedly simplifies setup and troubleshooting for service technicians. It’s available in sizes of 110, 150, and 199 MBH. weil-mclain.com
