No-Mix Foam Insulation
Icynene-Lapolla has announced its first no-mix polyurethane spray foam insulation, Icynene OC No Mix. Designed to provide long-term energy-efficient performance and cost savings, the formula does not need to be mixed on site. It is recommended for use in a structure’s critical insulation areas and creates a continuous air barrier once applied, according to the manufacturer. The formula may be used in any climate zone and applied across a wide range of temperatures. It firmly adheres to framing and substrates, and may be used to fill the gaps in stud wall construction. Installed costs vary by region; contact a local distributor for pricing. icynene.com
