Polyiso Insulation Product
Atlas EnergyShield XR continuous rigid insulation for use below grade
Engineered to provide continuous insulation for below-grade walls and under slabs, Atlas’ EnergyShield XR is a moisture-resistant polyiso rigid foam board with impermeable facers. According to the manufacturer, the prescored boards are easy to cut and are compatible with most mastic or solvent-based products. Pricing ranges from $19 to $70 a sheet. wall.atlasrwi.com
