Aluminum accent for board siding
Available in bronze, carbon, or gold, Millboard’s Envello Décor decorative and structural aluminum trim fits into the grooves of Envello Shadow Line+ composite siding, adding a metallic band between vertical boards to accent pop outs and rooflines or provide contrast across the entire exterior. When used with Shadow Line+ siding, the UV-resistant trim can span up to 35 1/2 inches on-center and is fire-rated, according to the manufacturer. millboard.com
