An Invisible Wrap for Open-Joint Claddings
Benjamin Obdyke has upgraded its line of building wraps with a new commercial-grade FlatWrap UV.
When paired with a rainscreen, the barrier provides increased bulk-water drainage and a vapor permeability of 35 perms. The wrap features a tri-laminate design with a high UV and tear resistance.
Specifically designed for projects with open-joint claddings, the black wrap is virtually invisible through the joints of a cladding assembly and does not require seams to be taped. The product costs $98 per roll online. benjaminobdyke.com
