Exterior Trim Products
Wood corner alternatives, urethane louvers and more.
By REMODELING Magazine Staff. Vantage Products. The company has re-engineered its vinyl siding accessories to accommodate siding up to 1 1/2 inches thick. Accessories feature reinforced locking positions and can be ordered in one of 300 colors to match any major siding brand. (800) 334-2238.
Crane Products. The company has added a 4-inch window and door trim profile to its PermaChoice siding trim product line. The profiles are made from an engineered polymer-based wood composite that is moisture-, rot-, warp-, and decay-resistant. Other trim pieces include a pre-primed outside corner, inside corner, and a J-channel. (888) 923-8799. www.permachoice.com.
Precision Composites. An alternative to wood corners, Royal Wood composite corner trim is engineered to withstand harsh weather. The product can be used as a general-purpose molding to replace cove, shingle, bed, and other molding applications. (866) 899-3320.
Courtesy Style Solutions
Style Solutions. Line of urethane louvers now includes seven half-round sizes and a round sunburst with molded trim. Existing products, including cathedral, vertical, peaked, and round styles, now include 10 new sizes. (800) 446-3040. www.stylesolutionsinc.com. Wolverine. Snap-on Lineals offer the appearance of wood casings but are easier to handle, install quickly, and do not require additional finishing, the company says. The vinyl trim pieces are available in white. (888) 838-8100. www.siding.com.
Alcoa. Designed specifically for bay window applications, this 45-degree corner is easier to install and is more attractive than standard 90-degree corners, says the firm. The corners come in white, cameo, desert sand, pebblestone clay, and gray. (800) 962-6973. www.alcoahomes.com.
