iLevel by Weyerhaeuser. Overcome design limitations for one of a home’s largest openings with the iLevel Garage Portal System. Incorporating the maker’s Shear Brace, TimberStrand LSL beam, and a proprietary portal connection, the Garage Portal System offers increased lateral resistance compared with traditional site-built garage fronts. Mounting brackets allow builders to adjust the system’s panels front-to-back to align with foundation bolts. The braces also have pre-drilled chases and holes for wiring and garage lights. Additional holes can also be drilled. 888.453.8358. www.ilevel.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
