Lightweight and easy to install, Evolve Stone Mortarless Series Stone Veneer can be used for both interior and exterior applications. Formulated from the company’s stone and glass-fiber composite, the veneer can be face nailed with stainless-steel finish nails using a standard finish nailer. According to the manufacturer, the veneer holds its color throughout, can be cut to fit on-site, is moisture impermeable and UV resistant, is not impacted when exposed to salt spray or freeze/thaw cycles, and performs well under wind loading. It’s available in five designs and four colors. Pricing varies by region. evolvestone.com
